Exede Question
Old Mar 30, 2005 | 10:48 AM
Kec's Avatar
Kec
Question Exede Question
Hey guys I just installed the Exede with the Stage 1 Map and when I turned the car on the light on the Exede is Yellow is that ok or did I messed up something with the installation any input will be appreciated thanks .
Old Mar 30, 2005 | 10:57 AM
gsujeff55's Avatar
when the car is running the light is yellow?
i think that means a map isn't loaded on the xede
Old Mar 30, 2005 | 10:58 AM
KLancer1997's Avatar
For comparison purposes, mine blinks orange when the key is first put in the on position. It goes green as soon as the car is started though.
Never heard of a yellow light. Link up to your XEDE and check the drop down menu that has XEDE info (or something to that effect) in it. It should tell you whether a map is loaded in the current bank you have XEDE set to.
Old Mar 30, 2005 | 11:25 AM
David@Vishnu's Avatar
Check for maps!
Old Mar 30, 2005 | 11:43 AM
Kec's Avatar
Kec
Hey is that light real green or is it yellowish-greenish ?
Old Mar 30, 2005 | 11:53 AM
Guess you could say it has a yellowish tinge to it
Old Mar 30, 2005 | 12:03 PM
Kec's Avatar
Kec
Than I think that I am ok it is definitely not clear green
and how do you guys upload and check the maps with xmap2 ?
Old Mar 30, 2005 | 12:15 PM
I cant remember the functions excatly and my laptops at home, but the drop down menus are pretty self explanitory. Sift through those and you should be able to find out everything you need to know. If you're still having difficulty later I can give you more detailed instructions after I get home.
Old Mar 30, 2005 | 07:04 PM
Kec's Avatar
Kec
I checked and the stage1 map is on the Exede but I don't feel any difference in power I am also using a Manual boost controller so how can I be sure that the Exede is working properly thanks in advance
Old Mar 30, 2005 | 08:11 PM
Vishnu_Evo8's Avatar
stage 1 should feel a whole hell of a lot different than stock. even on pump gas. do you have a boost gauge? if soo check your boost levels near redline.
Old Mar 30, 2005 | 08:50 PM
Kec's Avatar
Kec
The boost peaks 1.46 bar 21.17 psi and at the redline drops too 1.36 bar 19.72 psi and I am using a manual boost controller till I purchase the factory boost lines
Old Mar 30, 2005 | 08:57 PM
humm... on 91 u should hit about 22-23 psi. so your close. you dont feel a difference in power? not even 3rd gear pull?
Old Mar 30, 2005 | 10:36 PM
Kec's Avatar
Kec
Hard to tell I think that it pulls harder but nothing drastic so you think that I should set my manual boost controller for 22-23 psi ?and I am on 93 octane
Old Mar 31, 2005 | 12:21 AM
Ninj0x's Avatar
Maybe you should take off your MBC, the XEDE controls boost on it's own. (Just besure to remove the pill.)
Old Mar 31, 2005 | 12:32 AM
leif's Avatar
^ he said its on there till he gets the factory boost lines. you mite not wanna play with it too much till you get those, then hook everything up properly and reload the map and see what happends. i think on 93 octane you should hit around 23psi as well but the map will already be set for that....
