Shiv, Big turbo boost line routing 4 XEDE
Which way do you want the lines routed for XEDE boost control? Where does the restrictor pill go? Currently, I have my lines routed where the top port on the wastegate is VTA w/ the restrictor pill in between the turbo and the boost solenoid.
Currently, I am running a temp reflash from you and I would like to know if I can crank up the boost (25-27 psi w/ 100oct) to see if my intercooler piping will stay on.
I am looking forward to seeing you next Saturday.
Thanks
Thanks
David, the pill in my stock turbo setup was in between the turbo and the factory "T". Are you sure it goes in between the wastegate and the "T"? I just went and verified that there is no pill between the factory wastegate and the "T".
Well, I just tried both ways (pill in wastegate line and turbo line) and I have no boost control through the XEDE. It shouldn't matter that I used a slightly bigger hose from the "T" to the boost solenoid does it?
Originally Posted by David@Vishnu
OK thats fine now we can tune with it
Originally Posted by gsujeff55
did you unplug the green wire from the ECU and plug it in with the xede?
