Shiv, Big turbo boost line routing 4 XEDE
Originally Posted by gsujeff55
although, if you put another pill in there it should be running well over 17psi on the wastegate spring.
does your wastegate open at 17psi without a pill in there?
fwiw, the presence of the pill in the wastegate line wont affect the mechanical spring pressure of the wastegate so boost will not change.
What does change, however, is the sensitivity of boost level changes with respect to the wastegate control soneoid. In other worse, the more rectricted pill you put in there, the less duty cycle will be needed to raise your boost X psi.
hope that clears things up...
Cheers,
shiv
Cheers,
shiv
Cheers,
shiv
Cheers,
shiv
damn, thats strange
why won't a pill in the wastegate line change the boost the car runs? I thought it acted as a restrictor to let the turbo run more booost without the wastegate knowing it. I guess that would only work if the pill was on the wastegate side of the T huh?
damn, thats strange
Eventually the pressure will equalize.
damn, thats strange
tk2481
Feb 8, 2008 03:40 AM
