ATTN: Anything VISHNU
Old Apr 21, 2005 | 01:47 PM
Quickshifter's Avatar
I guess ill go try that .
But im not looking for stock boost
Old Apr 21, 2005 | 01:49 PM
jj_008's Avatar
Don't worrry. It won't be stock boost.
Old Apr 21, 2005 | 03:24 PM
well, you were right. It wasnt stock boost. it was like 15 lbs or something
I ended up taking a lot of value from the boost table.
all the numbers are like in the thirties now. ( I had no idea they would go this low to come back to normal boost levels.)
And now im having sort of a hard time controlling when boost is higher then other times (3rd gear jumps to 24 psi) but i lowered it a bit more and there all sort of equaled out around 20 lbs.
Damn......took me a long time to figure out how to do this (had no idea to go so low) but im glad i finally got this over with.
Shiv......when are you coming down to LA????????? I need your magic tune!!!!!!!
Old Apr 21, 2005 | 03:34 PM
jj_008's Avatar
You need to check the accuracy of your boost gauge. Wastegate pressure is about 11-13psi. I think your gauge may be your problem.
Old Apr 21, 2005 | 04:39 PM
gsujeff55's Avatar
well, it depends on the pill in there does it? if the pill is more restrictive than stock wouldn't it raise the boost some? FWIW, i have 2 pills in that line and im in the 30s to make 21psi in the mid range.
