V2 to V3 conversion cuts timing table in 1/2
Old May 12, 2005 | 07:58 PM
Jorge T's Avatar
Yaay for old laptops lol!
Old May 13, 2005 | 09:03 AM
crusin_lancer's Avatar
or set your resolution higher
Old May 13, 2005 | 09:36 AM
Jorge T's Avatar
800x600 is max, xmap likes 1024x768 minimum. I have 3 Shiv used my beater Zeitronix datalogger when he tuned my car.
Old May 17, 2005 | 01:20 PM
Jorge T's Avatar
Originally Posted by shiv@vishnu
Nope.. it's all included in the same firmware file. We're going to test the new firmware this weekend at Thunderhill and should post it up on monday.
Shiv
How did the new firmware work out?
Old May 17, 2005 | 01:24 PM
Bump for new firmware and xmap
Old May 18, 2005 | 10:03 AM
shiv@vishnu's Avatar
Everything seemed to work just peachily. Dustin's has been running the new firmware for a little while now. It interprets old v2 maps perfectly (although the changes to load variables still need to be made). The new firmware also incorporates the smooth start-up fix so just one firmware upload is all you need. Once upgraded, you will have to use the new version of XMAP v3. That will be posted up as well. It's too big of an attachment to post up here so we'll have to put it on the site. Hopefully, this will all be done today...
Cheers,
shiv
Old May 18, 2005 | 10:09 AM
Cheers,
shiv
Very nice shiv. Let us know when it is all ready to be downloaded.
Old May 19, 2005 | 11:56 AM
speedomodel's Avatar
Question
I've repaired my timing tables, but I ran the bad versions for a couple weeks. What issues would the halved timing tables have caused?
None at all. It's merely a display issue.
shiv
Old May 19, 2005 | 12:01 PM
Hi guys,
The newest beta version of both XMAP and the new Firmware can be downloaded from here:
http://www.vishnutuning.com/xede_support_evo.htm
The XMAP file is merely in executable. To make it work, put it in your current XMAP v3 folder and open it up from there.
Remember, the new firmware and software must be used together.
These updates fix the ignition-retard-cuts-in-half problem as well as the cold start start-up issue. You'll also notice a few other things in the software-- more on that later...
Toodles,
Shiv
Old May 19, 2005 | 02:03 PM
A418t81's Avatar
Shiv, is this the same Xmap and firmware verison that is listed in the sticky at the top of the forum? I just updated my Xede to v3 and d/l'ed the Xmap 3 software from Chiptorque. Do I need to do all of it again with the software you just listed above?
Old May 19, 2005 | 02:08 PM
Yes... the firmware and software I'm talking about in this thread is brand new.
shiv
Old May 19, 2005 | 03:27 PM
sr20det91's Avatar
Mines showing an "error loading xflash.dll."
Is this a big deal, or something to be concerned about?
Also, when I click on one of my maps it automatically opens the previous Version of xmap. Its V3, but the one without the cold start fix. Anyway to re-associate the maps to automatically open the most recent version, or do I have to open xmap first then open the map?
Old May 19, 2005 | 03:34 PM
ok... nm.
I'll go ahead and put together a full installation version to make things easier and troublefree
Shiv
Old May 20, 2005 | 12:51 PM
ok... nm.
Shiv
Bump for the bundled version.
