V2 to V3 conversion cuts timing table in 1/2
Old May 20, 2005 | 01:41 PM
  #31
Jorge T's Avatar
Originally Posted by shiv@vishnu
None at all. It's merely a display issue.
shiv
I'm confused now, when I entered the values manually did I change my map values?
Old May 20, 2005 | 01:43 PM
  #32
crusin_lancer's Avatar
I'm wondering this too. But when I changed them my car now feels like it did on v2, so I think that changing them manually didn't mess with anything. Bump for shiv.
Old May 20, 2005 | 02:21 PM
  #33
USP45's Avatar
If the car was tuned with the original V3 installed will the timing tables still be good? In other words, the car would have been tuned to the load presented not to the numbers on the screen correct? If the older version of the V3 is installed does the new V3 need to go in and if so will it automatically show the correct timing numbers? Sorry for all of the questions.
Old May 20, 2005 | 02:28 PM
  #34
i think starwars really did slow them down at vishnu today.
Old May 21, 2005 | 04:26 PM
  #35
ok... nm.
I'll go ahead and put together a full installation version to make things easier and troublefree
Shiv
Bump for bundled version! I have an auto-x tomorrow and wouldn't mind testing the new xmap and firmware out then, and I get "error loading xflash.dll" too. Get out of starwars land Vishnu.
Old May 21, 2005 | 08:08 PM
  #36
Bump
Old May 24, 2005 | 09:48 AM
  #37
Bumpers
Old May 24, 2005 | 10:38 AM
  #38
EVOtagger's Avatar
bump and subscribe
Old May 24, 2005 | 02:35 PM
  #39
x99percent's Avatar
Try copying the xflash.dll from your XUpdate directory to your XMap3 directory.
Old May 24, 2005 | 03:37 PM
  #40
I'll try that out tonight... thanks.
Old May 26, 2005 | 07:11 AM
  #41
PoloRL's Avatar
bump
Old May 26, 2005 | 08:36 AM
  #42
great man that worked perfectly... now to update my firmware. I noticed in the new xmap there is a selection for update firmware. Is this functional or should I still use xupdate?
Old May 27, 2005 | 09:35 PM
  #43
A418t81's Avatar
Shiv,
I just updated to the latest firmware revision that you posted in this thread and I have a question for you. I noticed that the latest firmware is some 3X larger than the previous one. Why is that exactly? Are there other cool things that have been added that we can't access w/ the xmap software right now?
Old May 28, 2005 | 10:31 AM
  #44
Jorge T's Avatar
Greyson, how did you get around the "com port COM1 invalid ,may be used by another program" message? did it still connect?
Old May 28, 2005 | 10:25 PM
  #45
A418t81's Avatar
Jorge, I got no such errors when I did the latest firmware update. I did get a checksum error, so I redownloaded the file and didn't change the filename like I did previously to remind myself which firmware version was the newest. It updated without a hitch.
