XEDE feature request: more maps!
Since you guys seem to be working on adding more and more XEDE features, I'd like to request that the XEDE should gain additional map storage space. 3 maps would be great, 4 maps would be perfect, IMO.
l8r)
l8r)
That's not possible with the current hardware. The vocabulary is a little tricky here. You're asking for 3+ banks of maps, not maps themselves. One map only modifies a single signal.
The current Xede hardware can only support 10 maps total. With two banks, you're already using 8 maps on the Evo. Therefor, the system is short two maps worth of memory for a third bank.
make sense?
d
make sense?
d
Originally Posted by Jaylenospoolboy
How hard would it be to install 2 xede units and toggle them?
d
I only use 3 maps per bank. Maps are only needed for signals that pass through the Xede. In my case, that's only MAF, MAP, and CAS.
Sure, a third bank would be nice, but then an extra wire would need to be devoted to a 3-position map switch (or two switches).
Possible? I guess...but is it worth 900 bucks to you to not have to haul out a laptop in the rare occasion you need a third map?
d
d
I wouldn't mind having these maps:
Valet
91 octane
100 octane
109 or 118 octane.
Originally Posted by Vishnu_Evo8
i dont know using mbc may give you an unwanted smoggie flash... and i heard those are expensive!!
his plan just didn't work quite as well as mine, i didn't use a MBC, i manipulated the xede....same thing though, except he had a faulty spark plug or some bs
