Just installed XEDE and need help...
I have XMAP 3.0.3.1
XEDE info:
Hardware Revision: REV Ba
Software Version: V3.1.08 16FEB2005
I just installed XEDE and here's what I did:
Remove replace boost (light green) wire/pin
Put all harnesses back together
Removed brass restrictor pill
Downloaded V2 Stage0+
Converted map to V3
Uploaded to XEDE
Burned to EEPROM
Turn off key
Turn back on and start car
When I press the acccelerator, the engine wants to stall. It seems to idle fine, but as soon as I press the accelerator it wants to stall.
Please help......
THANKS!!!
XEDE info:
Converted map to V3
Uploaded to XEDE
Burned to EEPROM
Turn off key
Please help......
THANKS!!!
Besides converting V2 to V3 you have to manually make some adjustments. If you haven't, it's explained in the tutorial. Link to tutorial https://www.evolutionm.net/forums/sh...54#post2086154
Steps 11,12,13. You may also want to update to the latest firmware available here http://www.vishnutuning.com/xede_support_evo.htm
I had the same problem the first couple of times I tried to flash a v3 map. I also threw a DTC (cel) for the MAF sensors everytime the car stalled because of this.
I think it was somehow related to the coldstart MAF issues. My fix was to wait for the engine to warm up, then flash. Regardless, the problem went away after 2-3 map uploads.
d
d
