Problem boost its been pulled by 4000 rpm
Old Jul 2, 2005 | 12:17 AM
RREvo's Avatar
Hi I think I have a problem I recently installed the 272/272 set to -2-2 and am running the stage 1+ (390) map with Xede Flash and my car boosts to 1.58 bar (22.9 psi) till it hits 4000 rpm than drops to about 1.18 bar (17.1 psi) and than slowly goes up till like 1.28 bar (18.5 psi) it does not seem normal to me when I run the stage 1 map it held steady 22 psi now that I have cams gears and am running stage 1+ map its giving me problems any advise would be appreciated thanks .
Old Jul 2, 2005 | 12:26 AM
gnulooks's Avatar
Try to change your cam gears to -4, -1. Sounds like the boost pressure is dropping off too quickly, even for a standard map. Also, make sure your running the right map for whatever octane your using.
Old Jul 2, 2005 | 12:33 AM
RREvo's Avatar
I am running a 93 octane stage 1+ map with -2-2 Andrew at Dyno4mance told me to do so you think that I should change it to -4 , -1 ?
Old Jul 2, 2005 | 12:36 AM
Dustin@Vishnu's Avatar
Do you have an xede flash?
Old Jul 2, 2005 | 12:38 AM
RREvo's Avatar
Yes just got it today
Semir
Old Jul 2, 2005 | 12:44 AM
You may want to see how adjusting the boost table makes the car react.
Old Jul 2, 2005 | 12:45 AM
RREvo's Avatar
Any suggestions what should I change in the table it always happens at 4000 rpm if I start a pull above 4000 rpm it stays steady by 22.4 psi
Old Jul 2, 2005 | 01:13 AM
RREvo's Avatar
bump
Old Jul 2, 2005 | 02:09 AM
RREvo's Avatar
Ok so can I just run the boost table from the Stage1 till 4000 rpm in Stage1 table I have 97.3 to the 3000 rpm and then changes to 96.5 by 4000 rpm then by 4500 rpm is 97.3 again the reason I am asking because I was fine with Stage1 map please let me know ASAP I am going to the track tonight thanks .
Old Jul 2, 2005 | 02:13 AM
RREvo's Avatar
so is there any reason that the Stage1+ map is lower on boost till the 4000 rpm because my base map for Stage1+ table is 92.9 till the 3000 rpm then 94.9 at 3500 rpm then 96.9 at 4000 rpm
Old Jul 2, 2005 | 04:42 AM
Dyno4mance's Avatar
Try putting the stage 1 map back in and see if this still occurs....
If not then mess with the new map....THE CAM GEARS ARE FINE!!!
Old Jul 2, 2005 | 10:24 AM
There is also the possiblity that you installed the cam gears 1 tooth off. It would cause the car to run somewhat normal, but be extremely slow, and have strange boost issues. I agree with Andrew.
Old Jul 3, 2005 | 01:54 AM
RREvo's Avatar
Ok now is a lil better the boost dos not fall off at 4000 rpm no more but now it falls at like 5500 rpm to like 1.28 bar ( 18.5 psi ) and then goes up to like 1.33 bar ( 19.3 psi ) any other suggestions or should I just adjust the boost table a little more at that rpm level ?
Old Jul 3, 2005 | 11:09 AM
Please check your cam gears. I have a strange feeling that they may be off a tooth.
Old Jul 3, 2005 | 08:45 PM
RREvo's Avatar
Ok so what should I check the notch on the Cam gears or the actually the timing by tooth let me know and my settings are -2;-2 thanks
