Want me to add in Launch Control?
Originally Posted by 93civEJ1
ok..now that we are getting launch control.....will we know how to invoke it when we want to use it? I mean what will cause it to turn off and on?
Also, to clarify, am I correct in thinking that launch control = NLTS (no lift to shift ... aka NL2S), as in they both use the same map?
l8r)
Originally Posted by Ludikraut
If I am understanding this correctly, when you have the map that includes launch control active on your XEDE, then it is ON (all the time) ... if you load a map that does not have launch control, then it's off.
l8r)
l8r)
i still dont understand...
Would that not make my rev be 6k all the time??
No....it makes it a particular RPM when the clutch switch is engaged.
Otherwise when the clutch switch is not being used the normal redline applies.
I cannot post my XM3 file to be modified.....invalid file type.....I suggest you just post instructions on how to add it ourselves.
sweet...ill have to try it out tonight...wooot.
its already up man..... http://www.vishnutuning.com/secret/
and can we use the boot wire that we have for the clutch after we are done with the v3 firmware upgrade?(assuming i can ever get mine to work)
Originally Posted by gsujeff55
you have to zip it up and attach it to your post.
thats what im going to do.
When launch control is active... sometimes when my foot is totally off the clutch pedal and the car is in neutral, the RPM's take a while to come all the way down. It seems to hang a bit around 4000. Is this normal? This also happens when the clutch is fully depressed the car with stagger around 4000 then slowly and I mean SLOWLY fall down. This started happening after I installed launch control. Other than this the car runs like a bat out of hell. The launch control settings have not been changed from the template.
maybe the thing shiv was talking about where the RPM catchup increase for launch control will help this problem??
Any thoughts on this? or anyone else for that matter that has messed with Launch Control/ NLS?
