Please look at data log and tell me what you think...
Old Aug 7, 2005 | 11:23 AM
  #31
A418t81's Avatar
Why don't you just register over at the innovative forums and then access the logworks forum and download logworks 2.0? Your LC1 will interface w/ you laptop using the logworks 2.0 and the cabling that came w/ the WB. You can then see exactly what the wideband is reading.
EDIT:
Here is the link to the software you need on your computer in order to access the LC1:
http://www.innovatemotorsports.com/s...gWorks2-b3.exe
  #32
Sackett's Avatar
I'm with joey on this one. If you read this post, shiv clearly states that a 50% AFR = 15:1, which is why in their instructions the car should idle at ~49%, which is around a 14.8:1 AFR
Perhaps we need clarification from Vishnu on this. did Vishnu reprogram the analog output of the LC-1s they shipped out to match this table??
Old Aug 7, 2005 | 11:35 AM
  #33
donour's Avatar
Originally Posted by joeycoates
Holy Bejesus!! If that is correct then my A/F's could be WAY off!!! Please let us know when you find out.....
Oops, I didn't mean to throw everybody into a tizzy. As I said, I bet those numbers are in some way modified by the Xede so the AN1 value may not match the actually voltage on the line. I'll get ahold of vishnu soon, but remember that it's not even noon on the west coast.
d
Old Aug 7, 2005 | 11:51 AM
  #34
donour's Avatar
Hm...I just found something worrysome.
Notice that shiv's table references the LM-1, not the LC-1. If you download the LM-1 manual (http://www.innovatemotorsports.com/support/download.php) you'll see that the LM-1 is factory set so that one can easily read the AFR off a voltmeter (it even references a 10-20AFR range). These are _not_ the same settings as we have on the LC-1.
d
Old Aug 7, 2005 | 11:59 AM
  #35
freedom's Avatar
For reference here is the LC-1 configuration as received from Vishnu,
Attached Thumbnails Please look at data log and tell me what you think...-widebandsetup.jpg
Old Aug 7, 2005 | 12:04 PM
  #36
Sackett's Avatar
OK, so this is the final word? Vishnu is reading .5 to 1.523 lambda from the LC-1?
Old Aug 7, 2005 | 12:06 PM
  #37
freedom's Avatar
Unless Shiv has the Xede modifying the input. But given that his table is so close I would think not. It is simply that he posted the LM-1 table.
Old Aug 7, 2005 | 12:24 PM
  #38
Sackett's Avatar
Even so, for anyone who has the XD-1 gauge, they will be seeing a different reading on the gauge than the XEDE is reading. we really need to know how the xede is interpreting the signals...
Thanks for all the info though guys
Old Aug 7, 2005 | 12:56 PM
  #39
Sackett's Avatar
OK, that would make this the table:
Code:
Volts	AFR	%	Lambda
0	7.35	0	0.5
0.05	7.5	1	0.51
0.1	7.65	2	0.52
0.15	7.8	3	0.53
0.2	7.95	4	0.54
0.25	8.1	5	0.55
0.3	8.25	6	0.56
0.35	8.4	7	0.57
0.4	8.55	8	0.58
0.45	8.7	9	0.59
0.5	8.85	10	0.6
0.55	9	11	0.61
0.6	9.15	12	0.62
0.65	9.31	13	0.63
0.7	9.46	14	0.64
0.75	9.61	15	0.65
0.8	9.76	16	0.66
0.85	9.91	17	0.67
0.9	10.06	18	0.68
0.95	10.21	19	0.69
1	10.36	20	0.7
1.05	10.51	21	0.71
1.1	10.66	22	0.73
1.15	10.81	23	0.74
1.2	10.96	24	0.75
1.25	11.11	25	0.76
1.3	11.26	26	0.77
1.35	11.41	27	0.78
1.4	11.56	28	0.79
1.45	11.71	29	0.8
1.5	11.86	30	0.81
1.55	12.01	31	0.82
1.6	12.16	32	0.83
1.65	12.31	33	0.84
1.7	12.46	34	0.85
1.75	12.61	35	0.86
1.8	12.76	36	0.87
1.85	12.91	37	0.88
1.9	13.07	38	0.89
1.95	13.22	39	0.9
2	13.37	40	0.91
2.05	13.52	41	0.92
2.1	13.67	42	0.93
2.15	13.82	43	0.94
2.2	13.97	44	0.95
2.25	14.12	45	0.96
2.3	14.27	46	0.97
2.35	14.42	47	0.98
2.4	14.57	48	0.99
2.45	14.72	49	1
2.5	14.87	50	1.01
2.55	15.02	51	1.02
2.6	15.17	52	1.03
2.65	15.32	53	1.04
2.7	15.47	54	1.05
2.75	15.62	55	1.06
2.8	15.77	56	1.07
2.85	15.92	57	1.08
2.9	16.07	58	1.09
2.95	16.22	59	1.1
3	16.37	60	1.11
3.05	16.52	61	1.12
3.1	16.67	62	1.13
3.15	16.83	63	1.14
3.2	16.98	64	1.15
3.25	17.13	65	1.17
3.3	17.28	66	1.18
3.35	17.43	67	1.19
3.4	17.58	68	1.2
3.45	17.73	69	1.21
3.5	17.88	70	1.22
3.55	18.03	71	1.23
3.6	18.18	72	1.24
3.65	18.33	73	1.25
3.7	18.48	74	1.26
3.75	18.63	75	1.27
3.8	18.78	76	1.28
3.85	18.93	77	1.29
3.9	19.08	78	1.3
3.95	19.23	79	1.31
4	19.38	80	1.32
4.05	19.53	81	1.33
4.1	19.68	82	1.34
4.15	19.83	83	1.35
4.2	19.98	84	1.36
4.25	20.13	85	1.37
4.3	20.28	86	1.38
4.35	20.43	87	1.39
4.4	20.59	88	1.4
4.45	20.74	89	1.41
4.5	20.89	90	1.42
4.55	21.04	91	1.43
4.6	21.19	92	1.44
4.65	21.34	93	1.45
4.7	21.49	94	1.46
4.75	21.64	95	1.47
4.8	21.79	96	1.48
4.85	21.94	97	1.49
4.9	22.09	98	1.5
4.95	22.24	99	1.51
5	22.39	100	1.52
Old Aug 7, 2005 | 01:10 PM
  #40
Sackett's Avatar
wow, making that change took my AFR from mid 11s to high 9s. Now i really wanna know what the deal is.. should SMART be tuning me to high 9s??
Attached Thumbnails Please look at data log and tell me what you think...-newpull1.jpg
Old Aug 7, 2005 | 01:24 PM
  #41
USP45's Avatar
I cannot see any way that you would be getting knock activity, no matter how minor, when running A/F's in the 9's. I guess we need some Vishnu input on this, I am sure that they would have compared their on board A/F readings to what the dyno read.....
Old Aug 7, 2005 | 01:47 PM
  #42
freedom's Avatar
Register with the Innovate forum and download the Logworks V2 beta 3 software. Jack into the LC-1 and log a run. The results will be whatever the LC-1 thinks it is reading without regard to what is going on with the analog output.
Note that Logworks on the CD that came with the LC-1 will not work with the LC-1. I know it doesn't make sense, but Innovate included the LM-1 software with the LC-1.
Edit: I read another post above that said the same thing. Until Vishnu responds, this is a good solution. In any case why not pick up a copy of Logworks....
Old Aug 7, 2005 | 10:39 PM
  #43
Jeff_Jeske's Avatar
Good to know I was getting angry.
Old Aug 7, 2005 | 11:00 PM
  #44
Sackett's Avatar
I did a couple logs of the LC-1, and it does look like my AFRs are running very low 10s, dropping into 9s at some times. but i am also seeing consistant knock events on the ~8 pulls i have done so far, some happening below 6000 RPM. what is going on here... btw i have a stock MR, using a copy of the 03-04 stock basemap.
How do i get the high-speed logging in xmap 3.2 to work? it keeps saying my COM port is in use...
Old Aug 8, 2005 | 07:35 AM
  #45
donour's Avatar
I dunno, but my software should work fine if you care to try.
http://pyxede.sf.net
d
