Is this Accurate info?
Old Aug 10, 2005 | 11:30 PM
wctej89's Avatar
Stage One Plus (v390) according to the Vishnu website (http://www.vishnutuning.com/evo_Stage1_v390.htm) is capable of doing the following:
0-60mph in 3.8 seconds
Standing ¼ mile in 12.1 seconds at 114mph
Are these numbers estimates or actual?
If the numbers are actual times recorded from a real evo; was the evo on race gas or have the test pipe on, and maybe include the Xede?
If the numbers are correct i am truely amazed because that would infer that a Evo with the Vishnu Stage 1+ package would be capable of beating 2004 Ferrari 612 Scaglietti (http://www.fast-autos.net/ferrari/ferrari612.html) 390hp vs 540hp (+800 lbs)
DAMN that is fast
Old Aug 11, 2005 | 12:07 AM
czevo's Avatar
I hope that it's accurate cus Im hoping to get this set up but with Xflash only
xede scares me a litlle
Old Aug 11, 2005 | 12:18 AM
wctej89's Avatar
yea i hope it is true also. Its up to the Vishnu guys to let us kno. That with 5G's we can start hangin and beatin on the big boys. Xede can be scary but once u learn how to tame it, it will reward you with power.
Old Aug 11, 2005 | 12:26 AM
czevo's Avatar
I downloaded some of the programs and you are right its straight forward once you look at
it
Old Aug 11, 2005 | 12:27 AM
czevo's Avatar
I just need something that i dont need to mess with to make power so downloading their
maps is prob all ill do i wont tinker much
Old Aug 11, 2005 | 12:35 AM
shiv@vishnu's Avatar
Depending on conditions, driver and octane, a v390 should trap anywhere between 111mph and 117mph. That's mid to very low 12s by most standards. 0-60mph will depend on how hard you want to work that clutch, what kind of surface you are launching on, and how long you want your transfer case to last. It's one of the advantages/disadvantages of AWD.
Shiv
Old Aug 11, 2005 | 01:06 AM
wctej89's Avatar
thanks shiv on your input it just assures that the package will deliver what it says its suppose to.
Old Aug 11, 2005 | 01:14 AM
eling99's Avatar
i ordered xede 2 days ago...and just before i read this thread..i felt like canceling the order...but i guess i wont now
Old Aug 11, 2005 | 06:53 AM
Smogrunner's Avatar
I'm a hack driver and I did a 12.2@113.67 with a pure stage 1+ (same as a V390). No other add-ons. (race fuel, no cat). Later, I put an intercooler on and the TME 10.5 ti turbo and did 11.9 at 115. Others have been faster than me. So, the numbers are accurate.
Old Aug 11, 2005 | 07:02 AM
gsujeff55's Avatar
I had race gas, and no cat.....and a 10.5 hotside and ran 117mph. so 114 can be done without the hotside easily.
Old Aug 11, 2005 | 07:26 AM
SuperHatch's Avatar
I had race gas on a pump gas map, and the minimum components required to have a stage 1+ with a Megan Racing O2 housing and I trapped 116MPH. This is accurate.
- Steve
Old Aug 11, 2005 | 08:09 AM
Ludikraut's Avatar
Just think what you could've done with NLS on that setup.
l8r)
Old Aug 11, 2005 | 12:50 PM
eling99's Avatar
wats nls?
Old Aug 11, 2005 | 12:52 PM
x99percent's Avatar
Originally Posted by eling99
wats nls?
No Lift Shift... aka WOT shifting
Old Aug 11, 2005 | 02:01 PM
Ludikraut's Avatar
...aka new XEDE feature.
l8r)
