Question for Vishnu
Old Aug 23, 2005 | 10:07 AM
KZEVO's Avatar
Question for Vishnu
Can you guys now reflash people with the P0300 Flash?
If not then what are the limitations for people who want to go the Stage 1+ route interms of power, boost, drivability etc.
Old Aug 23, 2005 | 10:38 AM
Calvin@Vishnu's Avatar
If you have the factory P0300 reflash fix, we will unfortunetly not be able to reflash you.
There are no limitations in terms of power, boost or drivability. With the Stage1+ you will get an all-round well performing car with very little, if any, compromises.
Old Aug 23, 2005 | 10:52 AM
KZEVO's Avatar
thanks for the response. what about tuning though? will it be a problem to tune? I think the flash raises the boost limit and rev limit right? so will i be stuck with a peak boost of 19psi?
Old Aug 23, 2005 | 11:39 AM
gsujeff55's Avatar
NO, you will be stuck with a peak boost of 22psi and a rev limit of 7600.
Old Aug 23, 2005 | 01:11 PM
Ludikraut's Avatar
Just bump up to the XEDE.
l8r)
Old Aug 23, 2005 | 01:58 PM
Vishnu_Evo8's Avatar
running the xede is almost like running a stock car, i have had one for 2 years now and not a single issue yet. If you dont get cams, there will be no way to tell if your car is modified or stock, but itl make 50-70 hp more.
Old Aug 29, 2005 | 10:02 PM
crispjaysalways's Avatar
I had a test pipe, down pipe and the ecu re-mapped and am wondering if it is normal to have the service engine soon light on? If I were to re-install the cat would the problem still persist?
Old Aug 30, 2005 | 12:02 AM
the-moss's Avatar
Can you perform the Xede flash on cars that have the P0300 flash?
Old Aug 30, 2005 | 05:26 AM
gsujeff55's Avatar
what code was pulled? that would tell us exactly why your CEL is on. But yeah, probably because your cat is gone, if you haven't done either an o2 simulator or the mechanical fix.
see here: http://www.forums.evolutionm.net/showthread.php?t=98573
the pics are down right now, but you don't really need em.
