Transition Lean Fuel Cut Debug Help Needed
Old Sep 25, 2005 | 02:18 AM
  #31
RREvo's Avatar
Any updates ?
Old Sep 26, 2005 | 12:54 PM
  #32
RREvo's Avatar
nothing yet ?
Old Sep 26, 2005 | 01:26 PM
  #33
Zeus's Avatar
WOW... just put the stock airbox on to test from the Buschur filter and BAM hit it! Got slammed with a fuel cut...
I'd like to see a response on this too!
Old Sep 27, 2005 | 09:54 PM
  #34
RREvo's Avatar
Well I guess we with this problem are on our own .
Old Oct 5, 2005 | 12:46 AM
  #35
RREvo's Avatar
bump
Old Oct 5, 2005 | 06:59 AM
  #36
Zeus's Avatar
Seems no one can, or will approach this subject...
Old Oct 5, 2005 | 10:23 AM
  #37
Dustin@Vishnu's Avatar
Here is something that has worked for me, but lets see if it works for the rest of you guys.
On the lean cut table, zero out the top 2 rows. combustion will not occur at that AFR, so there is no reason to have it cut MAF at that point. However, It does seem to prevent it from throwing the false cut under fast shifts.
Give it a try guys!
Old Oct 6, 2005 | 08:11 PM
  #38
RREvo's Avatar
Ok Dustin so you are suggesting to zero out the top 2 rows in the lean cut table so basically that table will be all zeroed out correct ?
Old Oct 6, 2005 | 09:13 PM
  #39
Im sorry, my table had negative 100s in the top for rows....zero out the top 2 rows, and then fill in negative 100s in the two rows below that.
Old Oct 7, 2005 | 12:05 PM
  #40
RREvo's Avatar
Ok Dustin here is the attachment off my 10 table map is that map now correct please let me know thanks .
Old Oct 8, 2005 | 04:06 PM
  #41
RREvo's Avatar
bump
Old Oct 10, 2005 | 08:35 PM
  #42
RREvo's Avatar
bump
Old Oct 11, 2005 | 05:34 AM
  #43
freedom's Avatar
You posted a shortcut not the map file.
Originally Posted by RREvo
bump
Old Oct 11, 2005 | 08:56 PM
  #44
RREvo's Avatar
Oh sorry fixed I posted the map now .
Old Oct 13, 2005 | 08:57 PM
  #45
RREvo's Avatar
bump for answer .
