Xede controlling water injection
Old Oct 1, 2005 | 09:31 AM
mmoranda's Avatar
Will the xede controll this aquamist 2c water injection kit?
http://www.aquamist.co.uk/cp/sys2c/sys2c.html
Old Oct 1, 2005 | 10:32 AM
rich728's Avatar
straight from the aquamist site:
System2c is specifically designed for such an application, you need to refer to the ECU manufacturer to provide an extra channel to drive the high-speed valve on the system2c (13ohm).
IIRC the high speed inline valve needs a 0-5v signal. XEDE will provide just that.
btw get a DDS3 gauge if you go with Aquamist. It's a really nice piece. Also call them in the UK and ask for teflon pump seals. You can run 90% meth 10% h20 long term if you install them.
Old Oct 1, 2005 | 10:48 AM
EvoTio's Avatar
The Aquamist HSV seems to be the issue in working with the XEDE directly. From what I understand, someone needs to figure out how to make the Xede PWM output compatible with the HSV. Richard Lamb of Aquamist has started his own thread on these forums for Aquamist questions if you want to check it out: https://www.evolutionm.net/forums/sh...ater+Injection I am running a Aquamist 2D set up with my Stage 1 on 91 octane gas. I am running my 2D independently from the Xede. Along with the S.M.A.R.T. system, it's working really well. As soon as there is I find out a way to intigrate the Xede with the HSV, I'll do it.
Old Oct 1, 2005 | 12:26 PM
mmoranda's Avatar
Thanks for the responses guys. Whats a dds3 gauge? I realy would like to have the xede automaticaly switch maps if there is a problem w/ water injection. I guess this lean protect map will help.
Old Oct 2, 2005 | 10:33 AM
rich728's Avatar
it's a 52mm. you can get either red or blue flow LED's
