V3 Map Request for HKS 280s
Old Oct 30, 2005 | 06:05 PM
sayanara's Avatar
Hopefully the vishnu boys can help. I need a decent base map for HKS280s on a stock motor. I have a turboback, fuelpump, camgears and 280s for a V3 XEDE. Thanks guys.
Old Oct 30, 2005 | 07:27 PM
madpacket's Avatar
I emailed Shiv asking for the same thing a month ago and never heard anything back.
Old Oct 30, 2005 | 07:29 PM
sayanara's Avatar
Hmm, well I hope we can get some assistance. Dustin has always been prompt with help. Did you eventually get a map sorted for the 280s, Madpacket?
Old Oct 30, 2005 | 07:40 PM
madpacket's Avatar
Nope. I have read elsewhere that you need to get the maps directly from Shiv. I could be wrong. I don't have the cams yet, so I didn't need the map yet either. But I wanted to switch maps as soon as the cams are in.
Old Oct 31, 2005 | 08:47 AM
shiv@vishnu's Avatar
Just use the standard maps for the 272 or 264 cams. The tweaks between the two are so minor that it didn't require another baseline map. Automatic SMART adjustments will more than compensate for it.
Shiv
Old Oct 31, 2005 | 09:03 AM
madpacket's Avatar
What about us non-smart users? heh. This may be an ignorant question, but is there a viable non-smart path, in the future? In other words will Vishnu end-of-life non-smart support of Xedes?
Old Oct 31, 2005 | 09:17 AM
Of course. Even nonSMART users can use the standard baseline for 264s and 272 when running 280s.
shiv
Old Oct 31, 2005 | 10:41 AM
sayanara's Avatar
Thanks Shiv. I'll give it a go with the 264/272 map, and see how it goes.
Old Nov 2, 2005 | 12:39 AM
Rushin's Avatar
With the 280's would we still have to run the -2 -2 cam setting? I understand that might not be optimal for those cams. IIRC +2 0 had good results. Would that require drastic changes in the timing table? I guess the basic question is - Does cam timing affect ignition timing?
Old Nov 2, 2005 | 02:36 AM
smokedmustang's Avatar
Do what Shiv reccomends above, I did , and it works fine. of course Andrew at Dyno4mance tuned it since then, but I used the map they told me to use! (see above).
