SMART Feature ???'s
Old Nov 8, 2005 | 07:17 AM
value's Avatar
SMART Feature ???'s
Can we still use a switch to change maps from a high boost to a street map with Smart?? Also with launch control I read you have to disconnect the clutch wire from the xede or put "0". Can we install a switch to turn off and on launch control ??
Old Nov 8, 2005 | 07:23 AM
donour's Avatar
Yes, you can use two map banks with smart if you want.
I suppose you could wire something up if you really wanted that behavior. Beware that you cannot use BOTH launch control and multiple maps.
d
Old Nov 8, 2005 | 07:58 AM
value's Avatar
Can't use L/C and a Meth map at the same time correct.
Old Nov 8, 2005 | 08:05 AM
donour's Avatar
No, i think you can use both of those features simultaneously. I was saying that if you want to have 2 map banks (which can be toggled with a switch), then you can't use launch control.
d
Old Nov 8, 2005 | 08:10 AM
value's Avatar
Got it thanks. Have to decide which I want to use.
Old Nov 8, 2005 | 05:48 PM
sandm's Avatar
can't you do a smart map and l/c, then switch to a race gas map at the track with a laptop?
or would there be no reason for this?
Old Nov 9, 2005 | 12:05 PM
Ludikraut's Avatar
yes, you could do that. It's just not as easy as flipping the switch from bank 0 to bank 1.
l8r)
