question of boost on v360 kit?
Old Nov 25, 2005 | 07:48 PM
  #31
jrsimon27's Avatar
yes thanks i know its only used with xflash but i did the comment cause if someone has a 2003 model and wants the xede instead of sending the computer fo a reflash wouldnt they also use the emulator as well? just a thought
Old Nov 26, 2005 | 12:14 PM
  #32
jrsimon27's Avatar
ok so i tried what shiv told me i did put all the readings on my boost table to zero and i went to try out the car and boost went to a low 0.7 bar so i guess my xede its doing a perfect job? so now what do i try as a next step??
another question do i see full boost in all gears or just in fifth gear passing 5000rpm??
thanks shiv
Old Nov 26, 2005 | 06:46 PM
  #33
Dustin@Vishnu's Avatar
Post your Map, I want to check something out.
Old Nov 26, 2005 | 08:35 PM
  #34
jrsimon27's Avatar
ok i will get my maps posted as soon as possible
Old Nov 28, 2005 | 11:41 AM
  #35
EVIL_EV0's Avatar
Have you tested for boost leaks?
http://www.vfaq.com/mods/ICtester.html
Old Nov 28, 2005 | 01:39 PM
  #36
jrsimon27's Avatar
ye i did and anyways is a new car.
Old Nov 28, 2005 | 02:17 PM
  #37
Jeff_Jeske's Avatar
I hope you dont think that new cars wont have boost leaks! LOL
Pull the vacuum line off the actuator and see how much boost it spikes to.
Old Nov 29, 2005 | 03:41 PM
  #38
jrsimon27's Avatar
thanks dustin with the new map it boosted more i will give you a call tomorrow to tell about it but thanks the car now feels great in the lower rpms!!
Old Dec 1, 2005 | 09:42 PM
  #39
jrsimon27's Avatar
hi dustin i was testing the car on a late night it was really cold and what i noticed was that my boost in 5gear passes the 1.5 bar the needle stays on top of the letters of the original boost meter is it ok that the car do this? do you think i can hit like 1.6 bar with 91 octane and stil be safe from doing any damage?? thanks !!
