any stock EVO IX and stock STI dyno graphs?
Old Apr 25, 2006 | 03:14 PM
Mmelmann's Avatar
Where are they at mang?
Old Apr 25, 2006 | 04:37 PM
boostedwrx's Avatar
from what ive seen the 9 is making a lot more low-end torque.
I wish I could get my powerband to shift up a little bit though, seems like a lot of the 9's grunt is at the lowend
Old Apr 30, 2006 | 08:56 AM
Mmelmann's Avatar
I haven't seen anything yet. I've searched here and over at nasioc and I've come up with nothing to show. I wish I could find something.
Old Oct 15, 2006 | 12:01 PM
jordo's Avatar
Originally Posted by Xerxes
Your numbers are dead on. I just elaborated on the Porsche numbers....
Stock 03-04 VIIIs 200-205WHP
Stock 05 VIIIs 210-215WHP
Stock STIs/STis 215-220WHP
Stock 06 IXs 230-235WHP
Stock 993 Turbos 305-310WHP
Stock 996 Turbos 315-325WHP
wow, thats pretty impressive..
I was very impressed by the power of a totally stock Lancer evo. I can only imagine one with 330whp.
Old Oct 15, 2006 | 02:39 PM
evobeatsti's Avatar
the evos tend to make way more hp but the stis own in torque b/c of the 2.5 l i was talking to the guys down at cobb and their stock 2005 evos made 227 whp and 248 lb ft on a mustang dyno at 5000 ft while stock stis made only 215whp and 232 lb ft on the same dyno. with tbe and flash the evo viii was at like 282whp and 260 lb ft of torque while the sti had like 30 less whp but 30 more lb ft of torque with same mods. i hope this helps
Old Oct 15, 2006 | 03:35 PM
fromWRXtoEVO's Avatar
Now days is difficult to find a couple of Evo and STI owners that actually dynoed their cars bone stock and from the same dyno.
Since I am a guy that knows a lot of STI and Evo owners and I happen go to a local dyno often here is just a couple of friends numbers:
04 STI bone stock from Kristiensen 18k miles 229 whp/239tq average of 3 dynos
05 Evo 8 MR from Eddy 11k miles 217whp/250tq
Both cars tested within 6 weeks on the same dyno at IAperformance. I don't have the dynos with me but can get them if needed.
Carlos
Old Oct 16, 2006 | 02:49 PM
Luke STIwalker's Avatar
I was at the Houston Dyno Day last weekend at Engine Logics and managed to get my car on the DD dyno after Shiv finished tuning all of the EVO's. I have a stock 06 STI with about 2,200 miles on the odometer.
Dyno Chart is in this thread post # 280: https://www.evolutionm.net/forums/sh...&page=19&pp=15
Old Oct 17, 2006 | 06:06 AM
3000ways's Avatar
I'm sorry but those numbers just seem awfully high for a stock STI. I mean that's just unheard of for an STi/STI, even one's with bolt ons and no tune would have a hard time matching that. It's one thing to dyno high, it's another to back it up with some 1/4 mile traps, I know the STI has to shift 5 times, so I'd expect a 104mph trap speed with that high of a dyno.
Old Oct 17, 2006 | 09:03 AM
I'm just as skeptical as you are, but you can ask Cajun Power (317HP on pump) and Resonance (284HP) who were there when my car was put on the exact same dyno and same day their cars were put on the dyno. When Resonance, on the v390 basemap, and I ran our cars several times from a 2nd gear roll up to the top of my 4th gear (100mph) , I'm right behind him (less than a car length). It isn't until I go into 5th gear that he really starts to put car lengths on me.
Old Oct 17, 2006 | 09:08 AM
tuffguy's Avatar
It would be nice to see the dyno numbers on the same graph from the same dyno to see how they match up at different points in the RPM. For example, to see how they compare at 2500rpm and how they compare at 5000rpm.
Old Oct 18, 2006 | 06:36 AM
3000ways's Avatar
Well anything is possible, you may have a factory freak, that blows other factory freaks out the water
Old Oct 18, 2006 | 07:48 AM
dayf's Avatar
That STI pulls a lot higher up in the RPM range than I've ever seen for stock. It doesn't seem to put out the torque as early in the powerband either. Hmm.
Old Oct 18, 2006 | 08:40 AM
My STI was dyno'd with the hood closed, so I'm wondering if the air guides for the TMIC in the hood scoop would make a difference on the top end power. I'm planning on having my car dyno'd again in Nov or Dec after a friend of mine finishes installing a VF39 (STI turbo) on his 06 WRX. We are going to try to get 4 or 5 STI's together for a little mini dyno day so we can compare all of our numbers together. Once we have a date set I'll post up on evom in case any EVO's in the Houston area want to meet up and hang out.
Old Oct 18, 2006 | 09:56 AM
KOEvo's Avatar
That will be good for comparison to your graph.
It looks like you don't get full boost until 4200 rpms? That's horrible, i thought STI's had better low end torque than Evos, you are spooling 1000 rpms later, and at much less boost to boot.
Old Oct 18, 2006 | 12:51 PM
How many RPM's does it usually take for a turbo to spool up assuming you are already at an RPM where it would make boost? I noticed the dyno didn't start until around 2,800 rpms so maybe that might have effected the beginning of the dyno graph.
