highest boost level on 91 octane
Old Dec 20, 2005 | 05:36 PM
wthoevo8's Avatar
If it peak 22.48psi you're Ok with a good tank of 91 octane, but if you're holding 22.48psi it's a little high, just incase you've a bad tank of 91. I think Vishnu tune 91 oct. with 21 psi peak. Hope this help...
Originally Posted by jrsimon27
i ask cause iam seeing in my car like 1.55bar which is 22.48psi? i just want to know if this is a safe boost level when using 91oct??
jrsimon27's Avatar
yes i know thanks but i have stage 1 from vishnu and i just want to know if its normal with this kit to spike to 1.55bar using 91oct i have in my xede the 91 oct program!
Old Dec 20, 2005 | 05:40 PM
jrsimon27's Avatar
it spikes to 1.55 bar when in low rpms and higher gears i push full throttle! also i hits like 1.52 and when it passes 5000rpms it spikes to 1.55 and lowers inmediatly to 1.48 or 1.47!
wthoevo8's Avatar
If it's spike to 1.55 you're OK. Make sure you've good tank of 91 octane (76).
Old Dec 20, 2005 | 05:55 PM
jrsimon27's Avatar
thanks ! well i use 91 oct from shell!
but do you think that is way on the limit of damaging something i mean detonation?
Old Dec 20, 2005 | 06:02 PM
wthoevo8's Avatar
It's OK to spike 22.48psi, if you're worry use 93 octane.
Old Dec 20, 2005 | 06:54 PM
Erik@MIL.SPEC's Avatar
Why are you using Shell? 76 is much better.
I peak anywhere from 20 to 22.5 psi, depending on conditions.
Old Dec 20, 2005 | 08:30 PM
awdjunkies's Avatar
i guess it depends on which evo (8 or 9) because isnt the boost set at 21 on the IX (Stock of course)?
Old Dec 21, 2005 | 12:52 AM
Style_Front's Avatar
Not that it contradicts any thing said here but shell and chevron are the same gas now. Chevron was bought out by shell, same with the chevron with techron gimmick.
Old Dec 21, 2005 | 01:01 AM
Vishnu_Evo8's Avatar
i ran 22 for 2 years with 0 issues. it sometimes peaks @ 23 psi.
Old Dec 21, 2005 | 10:11 AM
jrsimon27's Avatar
but i still want to know what vishnu thinks?? thanks
Old Dec 21, 2005 | 10:13 AM
jrsimon27's Avatar
dustin is it ok to hit 1.55 bar using 91oct?
Old Dec 21, 2005 | 12:20 PM
Since Vishnu8 and I were both tuned by Shiv, you should assume the answer is yes.
Old Dec 21, 2005 | 12:37 PM
they are on a min vacation.. im sure they will be back soon. (it is christmas time and all)
Old Dec 21, 2005 | 12:38 PM
b204dr's Avatar
24 psi on my 05 92 octane minnesota gas
