highest boost level on 91 octane
Old Dec 19, 2005 | 06:18 PM
jrsimon27's Avatar
hi friends i allready did a search and found to much contradiction!
but what is the highest and safest boost pressure you can have when using 91oct??
thanks
Old Dec 19, 2005 | 06:21 PM
SilverShadow03's Avatar
I'm running 20-21 peak boost. I've heard of 24 on a stock turbo but had arp head studs installed and other basic add ons.........hope that helps. For longevity reasons, I would keep it around 21 psi.
Oops....yeah...I'm on 91 CA **** gass......Tuned by Shiv at Vishnu.
Old Dec 19, 2005 | 06:29 PM
jrsimon27's Avatar
but 22psi or 23psi is that permited??
Old Dec 19, 2005 | 06:43 PM
probably, but I honestly dont know. I only can tell you what my car is tuned at and what I remember Shiv telling me.....give them a call or pm them....
Old Dec 19, 2005 | 06:45 PM
jrsimon27's Avatar
i ask cause iam seeing in my car like 1.55bar which is 22.48psi? i just want to know if this is a safe boost level when using 91oct??
Old Dec 19, 2005 | 06:47 PM
pharmd98's Avatar
no. Go no higher than 21 or you risk detonation and serious engine damage.
Old Dec 19, 2005 | 07:11 PM
fromWRXtoEVO's Avatar
I was doing 28PSI peak before and after the alcohol kit. I was able to hold 24-25PSI for a few seconds in 4th , 5th and 6th gear.
I ran my car at this levels on 91 basicly since I did the full exhaust, MBC CAI and the first tunning. Absolutely not a single issue of detonation yet.
Old Dec 19, 2005 | 09:10 PM
jrsimon27's Avatar
and what about our friends at vishnu what do they say?
Old Dec 20, 2005 | 01:37 AM
4GEvo63's Avatar
is that max boost at WOT in 5th gear?...i wanna get a MBC, but don't know how to use one...if i did, i prolly would've adjusted the boost to hit 19psi at WOT to 7000 rpm in 5th gear....please tell me that's right...
Old Dec 20, 2005 | 11:05 AM
jrsimon27's Avatar
yes but what does dustin at vishnu think?
Old Dec 20, 2005 | 05:23 PM
jrsimon27's Avatar
if anyone at vishnu sees this thread please reply!!
Old Dec 20, 2005 | 05:25 PM
wthoevo8's Avatar
They're close today, will be back Wed.
Old Dec 20, 2005 | 05:26 PM
jrsimon27's Avatar
ok thanks i will wait for tomorrow
Old Dec 20, 2005 | 05:32 PM
taenaive's Avatar
there isn't set pressure for 91 gas. it all depends on your car's condition and mods. For example, if you add more timing to your car, the car will detonate like crazy at even 18 psi. but if you really restard the timing you can push to like 23 psi. And during the cold winter, you can boost even higher. Only way to find out is to tune your car and see when it starts to detonate.
Old Dec 20, 2005 | 05:34 PM
SiCKlEyWiKeD's Avatar
I run around peaking at 22psi on my 05
