Vishnu and the GT35R
Since my GT3076 didn't get me in the 12's, I need to setup to a bigger turbo .
What is the smallest injector I can use w/ a GT35R. Currently, I use 680cc on GT3076. Would 680's be enough for 28psi on a GT35R? Out of curiosity, what injection duty cycle precentage do you guys see on your stage 2-3 w/ 680cc injectors?
Can I still re-use my timing map w/ the bigger turbo? I can re-adjust the fueling w/ the wideband pretty easily.
Thanks
Thanks
Thanks
Thanks
Best time w/ a stage 1+ was 13.8@105 on 92 oct and 13.5@108 on 100oct.
Best time w/ the GT3076 was 13.1@111mph on 92 oct. I ran it once on 100oct, but blew my stock coupler up at the TB.
Yes, my driving sucks. I need more turbo instead .
i did 12.3@114 with stock turbo,700inj,cams,10.5 hotside,full 3"exhaust,works flash p2r,800hp intercooler kit by trevtec here in vegas
Originally Posted by IE Evo
It is not the turbos fault! With a 35r u will still need driving skillz to get into the 11s. BTW, What is ur best time and MPH.
my buddy has evo1x did 13.5 with dp.testpipe,hks intake,1800 miles on it.
Originally Posted by razorlab
You only trapped 111mph on a GT3076? I think you need a better tune before a bigger turbo.
I am not an avid drag racer. I have gone 3 times ever. The only thing that I really cared about was I gained 6mph on pump going to the GT3076.
ill buy ur turbo kit and ill trade u my stock turbo,see maybe u goes low 12s
[why do u need a bigger turbo,u should stay w/ the stocker if u dont racer at all/QUOTE=jj_008]Tuning is fine. I just shift/drive too slow. I need an automatic EVO.
I am not an avid drag racer. I have gone 3 times ever. The only thing that I really cared about was I gained 6mph on pump going to the GT3076.[/QUOTE]
Instead of wasting your money on a new turbo why don't you improve your driving skill. It is almost free. When I can run 11's on a completely stock '04 turbo (no TME, no 10.5 hotside), it is a shame you can't even hit 12's with an upgraded turbo.
Trust me - you will be even slower with the GT35 turbo. Forget about it until you have gotten everything you can out of your current setup.
EVOlutionary
EVOlutionary
Its alot faster then w/ the stock turbo. The top end rush is amazing. The feeling of the car getting sideways when full boost hits when on race gas is sweet. In reality all I care about is the difference in trap speeds w/ one mod to the next. I drive my car the same way in order to be consistant. My brain can't handle 7000rpm clutch drops and NLS.
[/QUOTE]
driver mod needed? my stage 1+ hit 12.2@ 114 with a ****ty 1.87 60 foot and i was leaking boost from a loose hotside. and ie was cutting mid 11s all day with his 3037 on unleaded gas too.
I went 11s on a 1+ on pump.... I wish I could afford a 3076 setup... I'm doin enough advertising for vishnu every week at the track with my current setup, I could only imagine if I was going low 11s...
A bigger turbo, might actually be worse for you as far as 1/4miles times, with your current turbo you should easily be 11s. I see this all the time people buy the biggest and baddest **** but they dont spend any time getting good at driving what they have so they run **** times and then spend another 1k to run a little better time(but another bad time for what they have.). Whats the point of racing for trap speed, thats what fwds do.
JJ- Ive seen your car dynoed, you shouldnt have a problem running better times.
