Shiv, Injector duty cycle
What injector duty cycle do you see with 680cc on your stage 3 kit? Will 680's support a 63lb/min turbo at 23psi on pump and 28psi on 100 oct? Do you recommend positive numbers in the fueling table? Is adding +-4 equveilent to 1 AFR point?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Shiv
I figured going from a 52lb turbo to a 61lb turbo might cause me to run out of injector since I would have to start using positive numbers.
