Vishnu Dynoday @ TurboTrix in April
Originally Posted by Stephen Fisher
Big thanks to Shiv and to Troy.
I was a bit dissapointed in how my car performed. I have an 03 VIII with the V390 (except that I have an EBC rather than allowing the Xede to control boost).
Since my last tune (322hp/305tq), I added the TME with the 10.5 hotside, Nisei FMIC and hard pipe, and SMART (about $2,500 in hardware and software, not including install and tune).
After my tune today, I am at 340hp and 297tq. The hp gains appear to be consistent accross the curve (biggest gains at the lower rpm).
I am showing nice gains in tq at 3k RPMs (thanks TME). At about 3800 RPMs my new tq curve drops below my tq curve from my previous tune and stays below the curve thereafter.
While I am reasonably happy (but not overjoyed) by my gains in hp, I was expecting to see nice gains in torque from my tme and 10.5 hotside.
I know that I would have done a bit better without the EBC, but I had that for both tunes. I know that an FMIC does not generate hp or tq, but did I give some away to this? Did the SMART react differently because I did not give boost control to the Xede?
Any feedback would be appreciated.
Thanks.
SF
Thanks.
SF
If you have adjustable cam gears you may want to advance them 1or 2 degrees ie go from -3/-3 to -2/-2 to gain a bit of tq early but you may loose some hp up top.
Originally Posted by Jorge T
I would not worry about a 8lb-ft peak tq loss, this is probably caused by a bit of lag due to the larger fmic. You have 340 whp so you do have more tq across the powerband HP= (TQ X rpm/5250).
-shiv
Shiv,
I am sold on removing the EBC and will do so for your next visit to NJ. However, do you think that I have a boost leak or some other issue that would actually cause me to loose tq vs my prior tune after 3800 rpm?
I also noticed that my hp and tq curve cross on my prior tune at about 5800 (I thought they were supposed to cross at 5250)?
I am looking forward to seeing how the VIIIs do today.
Thanks for your help.
SF
SF
Shiv,
SF
SF
HP and torque will always cross at 5250. Sounds like your HP and Torque axis are scaled differently. Take a closer look at your graph. Your torque numbers may be higher than you think.
shiv
d
EDIT: 5252.113122032546 actually, given a 64bit approximation of pi.
Shiv,
I see why I was confused by my prior graph. The X axis is scaled in "speed (mph)" and the new graph is in rpm. That makes it very difficult to make a meaningful comparison.
SF
PS: How are the guys doing today?
SF
Shiv,
SF
SF
-shiv
Actually, the comparison is not that difficult. The data on the X axis (speed) covers approximately 52mph and the data on the X axis (rpm) covers approximately 5200. It looks like, for third gear, [(rpm/100) + 6 = mph].
It looks like, while gaining a little peak hp, I have lost significant area under the curve for hp and tq.
I will check for a boost leak when I have a chance.
SF
SF
thank you shiv for your excellent work! boy did you look tired today
thanks for your patience while i hooked up that nest of wires
thanks to jeff, diesel and everyone at tt for hosting.
have BIG fun in ohio shiv!
Well, I gotta say, what a fantastic day. There are many things in life where the legend is let down by reality but clearly, Shiv's abilities live up to the hype. His work on my Mazdaspeed Miata has it absolutely singing.
Laugh if you will at my mere 202 rwhp and 199.92 torque (Huge improvements over the 181 rwhp, 180 tq untuned) but at 2529 lbs, my car now has a better power to weight ratio than a new Porsche Boxter S, the original M Roadster, and even a Stock Evo IX. I'm not Evo bashing as I have an 03 Evo 8 but I got to say, this thing pulls just about as hard (Evo has TBE and flash). The numbers are only part of the story as the driveability is phenomenal. Pull all across the board. Visions of a fully prepped SM2 car are now dancing through my head. Hmmmmmm....I can't stop grinning
Shiv, thanks for your patience in getting me the kit and for all your hard work tuning it. It was a pleasure to meet you and I'm sure it won't be the last time.
Troy, thanks for organizing everything. Your efforts were much appreciated.
Big thanks to Turbo Trix for letting us use their awesome facility. Glad I have you guys nearby.
Great meeting everyone. Great bunch and some sweet cars.
-John
2004 Mazdaspeed Miata
Vishnu Stage 0
Flying Miata Turbo back exhaust (with cat)
202.05 rwhp 199.92 tq at the hands of Shiv
-John
Vishnu Stage 0
All,
As soon as I get the results from Shiv, I will post in the Thread Starter.
It was great meeting everyone - Thanks for making it one of the smoothest Events I've attended
Thanks, Troy
Thanks, Troy
-John
Vishnu Stage 0
-John
Vishnu Stage 0
