Am Unplugging Xede Tomorrow to Troubleshoot!!
Old Jan 21, 2006 | 06:47 PM
smokedmustang's Avatar
Unhappy Am Unplugging Xede Tomorrow to Troubleshoot!!
My problem of WOT misfire, machine gunning, hesitation is GONE. I can go from a stop, to 7K, shift, repeat, and the boost climbs, No misfire. That is the good news.
Tonight I was out, and had the car in 5th gear, about 3K rpm, and I stepped on it, and I heard the POP-POP return. It came on quickly about 3250-3300 RPM, like when I put more gas in it. Immediate. And the clunking is still in my glovebox, and wont go away. I will try to disconnect the Xede, and just run the Xede Flash. if the problem is gone, could it be something in the wiring harness? any other ideas?
I later stopped on a country road, and took off "quickly" getting to 22psi of boost, WOT, and the problem did as the first sentence says. NO PROBLEM THERE! If I am in 5th, at 3K rpm, and stomp on the gas (not harsh to the floor) but quick on the gas pedal, this issue returns. I can take a video of it tomorrow, so you can "hear" it for your self. It is amplified obviously, with the use of the side-pipe. I will post it on here tomorrow so you can SEE and HEAR what I am talking about.
Will film my boost guage/AEM UEGO gauge on the dash, and what they do when I get the Pop-pop. Yet another expierement is under way!!!
Old Jan 21, 2006 | 06:54 PM
gsujeff55's Avatar
that car has freakin deamons....thats my expert analysis
Old Jan 21, 2006 | 06:56 PM
well then........that solves that! I will just call Father O'malley, and do an exorcism!
Old Jan 21, 2006 | 07:00 PM
gsujeff55's Avatar
seriously, everytime i read one of your posts your car is doing something retarded....i think it doesn't like you, did you blow a load on your recaros?
Old Jan 21, 2006 | 07:05 PM
I need anger management. You havent been on here for months, and when you do return...........wallah!!! I am still beeatching about something else, so in effect, you havent missed a thing!!!!Different part, different dilema, but still DRAMA!!!
Old Jan 21, 2006 | 07:07 PM
Vishnu_Evo8's Avatar
you will need a young preist nd an old preist
Old Jan 21, 2006 | 07:10 PM
I have them on the rolodex, had to use them to straighted my wife out!!!
Old Jan 21, 2006 | 07:12 PM
jj_008's Avatar
I'll bring the holy water .
Old Jan 21, 2006 | 07:15 PM
everytime I go near Holy Water, it starts to boil, so that is a bad sign.
Old Jan 21, 2006 | 07:21 PM
Tomorrows video clips:
1. What the "sound" sounds like, and where on the rpm band
Will do from stop,7k RPM shift, most gears. (saftey first) and in 5th gear and stomp!
2. See What the gauges are showing me at the time of the "machine gunning"
3. What happens with a coil change?
4. What happens with the Xede Dis-connected.
This might help some of you, and bore the rest of you. You will hear what I am talking about.
Old Jan 21, 2006 | 07:24 PM
Event-Horizon's Avatar
maybe its just too cold where you are and you're running too much boost? What boost levels are you running?
Old Jan 21, 2006 | 07:28 PM
It is a bit chilly, but when I stepped on the gas in 5th gear, I would assume the boost went up to maybe 10psi? I wasnt hard in the boost there when the problems started. I was hard in the boost from a stop to 7K, 2nd to 7K etc...
Old Jan 21, 2006 | 07:43 PM
Eclipse2Lancer's Avatar
5th and 3k RPM?? How fast is that young man??!!
Like P-Diddy says: Mo money Mo problems.
Hope to solve tomorrow
Old Jan 21, 2006 | 07:47 PM
gt420hp's Avatar
5th and 3,000 rpm your probably doing about 70 mph or so. I had the same thing happen, stomp on it in 5th gear with it around 40 degrees and you get a hard, really hard shutter in the car and the check engine light pops on. Its from your mass air thinking too much air is coming in...plus you are putting strain on the turbo stomping on it in 5th. You need the ECU reflash to remove the factory mass air setting preventing overboost.
At least that is what it sounds like to me....
Old Jan 21, 2006 | 07:54 PM
x838nwy's Avatar
It's all them stickers doing it.
