? regarding flow restrictor in boost line
If I was to temporarily disconnect the XEDE (run directly off stock ECU)and not replace the the brass restrictor in the boost line. Would the boost be higher or lower than stock? This is on a 2003 Evo.
If the BCS is hooked back up to the factory computer, it generally causes for unstable boost. You will notice that your car may spike higher than stock, but run less boost at redline. With the BCS disconnected, you will see mechanical wastegate pressure, which is 12 pounds.
-Dustin (pretending to be sean.)
