V390, Xflash, and Injectors?
I'm putting my cams and cam gears in to go to V390 at the end of april. When looking at the vishnu site, it says an xflash is recommended for this level. I was going to wait until I put them in to see if I hit fuel cut before I decide to send out my ECU. Now with that being said. If I have to send it out, I was thinking of doing my injectors at the same time so I only have to send it out once. I have an smc alky kit waiting to be installed also. What injectors would you guys recommend (size, brand) for a setup like this? And can Shiv flash for any volume injectors or are there just specific ones? Thanks
Keep the stock injectors. No need to upgrade if you are retaining the stock turbo. Especially if you are going to run methanol which reduces fuel injector demands even more.
shiv
shiv
thanks shiv. i just searched and found a thread about how to view idcs (yes i searched!!!). i'm going to see if i can hook it up and then monitor it with all the changes. thanks again.
