Serial port connection adaptors
Old May 26, 2006 | 09:57 PM
GokuSSj4's Avatar
what are some brands that will work with a laptop that doesnt come equipt.
i have been recommended serial port adaptor to USB made by Keyspan
also express card expansion adaptor made by socket...
what brand are you guys using or what works and what doesnt ?
and where to purchase ? also what laptop do you use in order to log or change your Xede maps and what do you recommend ?
Old May 26, 2006 | 10:48 PM
dude's Avatar
Search my friend. Search. I'm too tired to find them for you, but there have been plenty of posts on the subject. You can even use my user name as I've posted information on what brands work in several of the threads, I just can't remember it was so long ago.
As for a laptop, any old one will do, XMAP doesn't take much computing power at all to operate. If you're going to do quite a bit of your own tuning I'd suggest buying one of those used $300 dollar couple-year-old IBM Thinkpads off ebay. They're cheap and have a dedicated serial port on them and try as I may, I can't get a USB to Serial to give me the same refresh rate.
Old May 26, 2006 | 10:53 PM
diiirk@AwdMotorsports's Avatar
COMPUSA has them...made by keyspan...its a serial to usb...i work at compusa...there in the upgrades section
Old May 26, 2006 | 11:38 PM
EvoBroMA's Avatar
aparently alot of usb to serial adapters use the native windows driver, and yeah - the windows driver sucks for refresh rates.
Old May 27, 2006 | 01:31 AM
and yes windows is garbage for many reasons.. its all about the macs
Old May 27, 2006 | 04:18 AM
DCSilvrEvo's Avatar
Sike... Not In Gaming! Mac's are HORRIBLE for games.
Old May 27, 2006 | 07:01 AM
donour's Avatar
I have both this one:
http://www.radioshack.com/product/in...entPage=search
and this one:
http://www.amazon.com/gp/product/B00...Fencoding=UTF8
They both work great for a variety of applications and a several operating systems.
d
Old May 27, 2006 | 07:03 AM
donour's Avatar
Oh how behind the times you are. My Macbook pro is a speed demon as portables go. It even runs windows if you want to play directX stuff -- too bad I don't.
d
Old May 28, 2006 | 09:35 AM
GokuSSj4's Avatar
and this one:
d
thanks! i was able to get the radioshack to work with my laptop..
I didn't have good results with the keyspan adaptor...
Old May 28, 2006 | 11:30 AM
nothere's Avatar
what is it with aftermarket hardware and their love affair with serial plugs?
Old May 28, 2006 | 11:44 AM
EvoBroMA's Avatar
its a billion times easier to code for serial than usb. plus the code for serial is already out there.
what developers should be doing is using usb to serial ICs and Virtual Com Ports. As far as the software is concerend its just another serial port, except we getto plug it into a usb connection. This is what CBoles did with his tactrix cables. Such a simple/good idea. not only that the convertor comes with its own VCP drivers not the windows ones.
Old May 29, 2006 | 06:50 AM
donour's Avatar
Except that Ecuflash doesn't use the VCP driver. It uses the D2XX driver which isn't available on all platforms.
d
Old May 29, 2006 | 06:55 AM
steevo's Avatar
The only serial port emulator I have had success with in other applications is the Socketcom PC Card adapter. It's $149, but worth it. I have to connect these things to stupid serial port devices all the time. Guaranteed to work. Check it out....http://www.socketstore.com/product.asp?sku=1020653
Old May 29, 2006 | 07:22 AM
GokuSSj4's Avatar
thanks ! since Mike W and Scot G have highly recommended this product as well, since they happen to use a serial connection adaptor when tuning the EMS .
Old May 29, 2006 | 07:29 AM
damianhindley's Avatar
d
I second that, ill put my 1.4ghz ibook vs any pc latop of a 2.5 and below and it will blow it away. My outer has yet to be restarted or turned off for any reason in 5 months. oh yeah, just works, always works. I have a garbage thinkpad for my car though. I am looking to get a macbook. The reasle value on macs is crazy Mine will sell for about $1100 thats only a hundred bucks less than i paided for it a year ago. I want the macbook pro, but my budget wont work with it. I have yet to see a notebook that can come close to the pro.
