V550/Stage 2 Help
V550/Stage 2 Help
1) support bracket- should this use the stock bolts or should the kit have come with shorter bolts or spacers? my stock ones are far too long.
2) waste gate- this came with big blue and small red spring 1.4 bar or 20.3psi with boost tables at 0. i have no problem with this, but that means no taper below 20.3 right?
3) intake pipe- how does this attach to my BOV? there wasn't a silicon or rubber attachment in any of the boxes. do i need to locate a proper sized silicon coupler for this?
4) injectors- i sent these in to RC for cleaning prior to installing them. they are 680cc, but prior to cleaning they flowed 640, 624, 644 & 617 after 653, 648, 656 & 646. these are brand new. i'm ok with the flow on these, but i sent my ecu to be injector scaled and am worried that i'll run lean since i'm going to be scaled for 680cc and don't even hit 660cc. maybe smart will take care of this.
i'm sure i'll have more questions once i get further into it.
thanks
vincent
thanks
vincent
vincent
vincent
thanks
vincent
thanks
vincent
We had a similar issue with our kit not having all the parts. Contact Dustin, he should be able to set you up.
Originally Posted by NEW2006EVOIX
Make sure to place the 656 in cylinder #1 (nearest timing belt) since that is the leanest running cylinder.
i would but there is no way of knowing which is which.
i went with the 3076. decided to upgrade from my tube mani 3076 setup. did you install yours?
I got it second hand, though.
Chris, if you were talking to me i sold it about 2 months ago. i posted it up here in the south region and the FS threads. if i knew you were interested i'd have pm'd you to let you know it was for sale.
vin
vin
