The Cam Timing Challenge
I have an appointment next Wednesday with Tuner Transformation star Shiv Vishnu and would like to hear some peoples theories on cam timing. I will probably only have enough time to do 4-5 changes. Right now, I am at -3,-3 so that will be my baseline. I will probably do 0,0 as one of my data points. My goal is to improve my torque curve, even at the expense of peak horsepower. This should be a neat experiment.
Let the theories fly
yeah. there are like two huge threads on this. i think one by ted b and one by quicksilver. it basically boils down to what you'd like:
for 264s, 272s, or combos:
more torque, flatter power curves, lumpy idle = -2,-2
less torque, higher peak horsepower, smoother idle = -4,-1
Originally Posted by Vishnu_Evo8
tuning celebrity shiv vishnu?
http://www.vishnutuning.com/images/N...age_index3.jpg
Now, you have straight 270's, so check with TedB, but on my staggered combo, Ted's recipe of +2i/0e, transformed my car, which had originally been set at -3/-3, into a super torquey, much faster-spooling beastie.
I am not even curious about experimenting with other possible settings. TedB is The Man. Now, m y car hits peak boost(19.5#) by 3100 rpm in 5th, when mashed from 2500 rpm. You have the bigger turbo, so I would imagine that you wanna improve spoolup and low end grunt. Well, the advanced settings are where it's at.
As a side benefit, with +2/0, you get that really spooky, spilunking idle, with which to ward off innocent pilgrims.
Originally Posted by MalibuJack
You never saw that show Tuner Transformation? I even grabbed a still off it with the caption "Shiv Vishnu" as his name just as seen on the show.. Its posted up here somewhere..
I've tried a few different combos myself but was unable to try:
+1/-1
+2/0
I am running -2/-2 which provided me with the best overall curve and about 1k sooner peak torque than 0/0.
+1/-1
+2/0
