XEDE and Aquamist...
Old Jul 13, 2006 | 10:45 PM
jj_008's Avatar
Look what I did...
It works and I am happy .
Old Jul 14, 2006 | 09:45 AM
alan678's Avatar
Intercooler spray??
Old Jul 14, 2006 | 10:46 AM
EvilBlueEvo8's Avatar
yeah what the heck is it?
Old Jul 14, 2006 | 10:47 AM
jj_008's Avatar
Originally Posted by alan678
Intercooler spray??
Nope. The water goes into the intercooler pipes.
Old Jul 14, 2006 | 10:51 AM
alan678's Avatar
??? Care to share the specs of this idea and whats it actally does ???
Old Jul 14, 2006 | 11:17 AM
jj_008's Avatar
No problem. I am using a flowmeter to monitor flow through my water injection system. If there is no flow (line breakage, line clog, pump dies, hole in line, empty tank etc) then the voltage drops and hits the 0 cells which pass through the values in my MAF pump gas map. If line breaks or leaks at the nozzle (more flow) then it hits the 0 cells in the upper voltages. When everything is working fine it leans out my AFR and adds more timing advance. Basically, I have created a closed loop water injection control.
Old Jul 14, 2006 | 11:35 AM
Jeff_Jeske's Avatar
I don't see any advance!
Old Jul 14, 2006 | 11:43 AM
jj_008's Avatar
Anytime you pull out fuel, you will add more timing.
Old Jul 14, 2006 | 01:54 PM
Jeff_Jeske's Avatar
But you are putting fuel (alchy/meth) back in. It also looks like he is pulling ALOT of timing.
He would probabaly see better returns running a fatter AFR and then add/zero timing in the timing table.
Old Jul 14, 2006 | 02:18 PM
jj_008's Avatar
Shiv custom tuned my car for pump gas. I have to have negative numbers in my timing due to the amount of fuel that is being taken out (which advances timing as a side effect).
In my new map, I am pulling more fuel since I am now adding another fuel (meth/water). A side effect of pulling fuel is adding timing advance.
Old Jul 14, 2006 | 06:22 PM
Jeff_Jeske's Avatar
The addition of timing by leaner AFR is true. But, you are not going any leaner because you are adding a second source of fuel.
