Help, EXDE light flashing Red, orange, and green
Old Sep 7, 2006 | 10:24 PM
JMB8606's Avatar
I just had a new 2.3 strocker put in by RRE and there seems to be a problem with the exde. The light flashes orange with the key is in the on position. They said they start they car it flashes green, then they rev the engine and goes from red to orange, than green, what is the problem. RRE says it about 80 degress there. I have driven the car with temps over 100+ with no problems
Old Sep 7, 2006 | 10:45 PM
Spec'd's Avatar
WTF !? ... That's crazy. Maybe a loose connection ?
What else did they do besides the stroker ?
There are guys running the Xede with strokers and GT35 turbos.
Old Sep 7, 2006 | 11:04 PM
JMB8606's Avatar
strokers was perty much it. They removed the perrin boost solenoid. and hooked the boost lines so it would run off the wastegate
Old Sep 7, 2006 | 11:31 PM
sparky's Avatar
You might wanna call Tuning Technologies in Colton, and see if they'll troubleshoot your XEDE for you and tune it for the stroker.
Out of curiosity, and because I simply have nothing better to do, I went out to the garage, and fired up the beast. The XEDE light goes to red with key-on, then switches to orange, then flashing orange after five seconds, then goes full green, once engine is fired up.
Old Sep 7, 2006 | 11:47 PM
JMB8606's Avatar
thanks
