XEDE Help
Old Oct 25, 2006 | 03:51 PM
  #31
McDougal's Avatar
Stupid question, but what is the boost setting for the base maps. I believe I am running the V300 map as my car is pretty much stock. Thanks in advance.
Old Oct 29, 2006 | 06:20 AM
  #32
brodienuchies's Avatar
Here is what is posted on Vishnu's Website about the SubZero Map :
These maps are designed for a completely stock 2005 Lancer Evolution running 91, 93, or 100+ octane fuels. The brass restrictor pill in the boost line just before the factory boost control solenoid must be removed. In addition to raising boost by approximately 1psi and holds it more constantly to redline. It also induces a more aggressive timing and fuel mapping values. Use only with premium unleaded fuels.
Unless you have removed the restricter pill I think your still at around stock boost. Otherwise as stated above you should be around 19-20psi I believe.
Anyone no for sure on this one?
Old Oct 29, 2006 | 06:27 AM
  #33
Spec'd's Avatar
Yes 19 to 20psi sounds about right.
