Map for FP Evo Green
Old Apr 14, 2007 | 06:14 AM
dsmythe2's Avatar
Originally Posted by svtkiller
Andrew can get you around 360awhp on 93oct @25lbs of boost tapering to 23 and around 400awhp on 110oct @ 27lbs of boost. You'll also need 770cc injectors or around there. Andrew charges 5hrs to install the green. I just talked with him yesterday about it.
That's just about what I'm looking for.
Old Apr 14, 2007 | 01:34 PM
sparky's Avatar
Since the Green compressor flows practically the same 47-49 lbs./min. as does the Garrett 3071 and there are quite a few examples of XEDE maps for the 3071, do you think that it would be logical to at least try an XEDE map done for a 3071.
Maybe since the 3071 is a bit laggier, then you might have to add a bit of fuel under 4500 RPM, when tailoring the fuel table for the 20G-LT. At least this way you wouldn´t have to build a map from scratch.
Old Apr 14, 2007 | 08:18 PM
jrsimon27's Avatar
use a 91oct map from the sit so that you dont start from scratch and then tune it using a wideband and a logger like evoscan or mitsulogger and you will be set.
Old May 18, 2007 | 08:03 PM
EvoRecordSetter's Avatar
how does the car even run on 89 octane.... let alone with a green with mods. lol
