Which XMap version is the most current one for SMART v390 setup
Old May 14, 2007 | 08:50 PM
Bexa20's Avatar
I used to have the v330+ setup, but recently I upgraded to v390 stage with 10.5 hot side. I was successfully tunned by Shiv. When I tried to connect my laptop to the Xede and tried to download the maps from the Xede to the loptop I got the following message "XMap and Xede data does not match" (pic #1) When I checked for the version that was installed it said it is the 3.2.0.7 (pic #2.) I went home and searched for new software, I found XMap versions available 3.2.0.16 and 3.2.0.17. I think .17 is a hybrid one (is this for the 272/264 setup??) So I believe I have to use the 3.2.0.16. Could someone verify this for me. The firmware on the Xede should be fine because I asked Shiv to check it before he started tunning.
Old May 14, 2007 | 08:54 PM
Bexa20's Avatar
Forgot oto upload images
Pic #1
Pic #2
Old May 14, 2007 | 09:29 PM
Evo23IG's Avatar
The Xmap you have in the pictures doesn't look like mine, it doesn't any have smart tables.
Old May 14, 2007 | 09:53 PM
Bexa20's Avatar
I know this is the version that I used for the old maps which were not SMART enabled. I'm looking for the right version for the SMART configuration.
Old May 15, 2007 | 09:22 AM
juyanith's Avatar
I believe that the "maps don't match" error is a bug and can be ignored and, if I recall correctly, my smart mapped v390 used version 3.2.0.7. I never bothered to upgrade to the .17 version because it would require updating the Xede hardware. The only difference I'm aware of is that the newer version supports conditionals (and thus you could eliminate one of the tables). Perhaps someone at Vishnu will chime in with more information.
Old May 15, 2007 | 12:30 PM
Bexa20's Avatar
can you guys give me some feedback on which version you are using??
