Q: How ca I disable the timing Map and still make the car start?
Q: How can I disable the timing Map and still make the car start?
I still run the XEDE for a boost control I like the stability of the XEDE boost plus I can store 2 boost maps. I have all fuel and timing are zero'd out. I feel the timing signal replication is limiting the amount of timing I can run.
How can I make timing pass trough...I tried disabling by deleting the timing map...the car would not start. I jumpered to bypass XEDE the crank in/crank out wires, car would start but Xede would go into fault mode and no boost.
I don't want my Xede become a paperweight
I took the crank in and crank out (pins 8 and 5 of the grey connector) and bridged them together. Car starts fine but XEDE misses the signal and goes blinking orange. There must be a way of doing it via software but I don't know enough about programming. This is the contents of the latest Pattern file
Recipe File for XEDE TSP
[File Info]
Original Date=5 Aug 2004
Original Author=RD
Revision=V1.1
; V1.0 5 Aug 2004: Prototype; no versioning adhered to really
; V1.1 3 Apr 2006: Add wired bypass lines
Revision Date=3 Apr 2006
Copyright=(C) 2006 ChipTorque
[Vehicle Info]
;This info is stored in EE; total < 32 characters
Waveform=4-Even, Hall Rising
Vehicles=Mitsubishi 4
[TSP Setup]
Prescale=36
Shift per Change=1
: 0.1 deg
Edges per Change=200
: shift by 0.1 deg every 20 degrees
Active Edge=Rising
Error Detection Enabled=0
Error Tolerance=25
: percent
Pattern Sync Address=1
Sync Pulse Count=2
: = pulses - 1 in this case
: For PP-only case
Sync Method=Pulses
: Either 'Comparison' or 'Pulses'
Comparison Type=PP
: Either 'PP' or 'PW'
Greater Than Next=0
Greater Than Previous=0
Sync Threshold 0.25=0
Sync Threshold 0.5=0
Sync Threshold 1=0
Input Hysteresis=10
: Must be < 127
Minimum Pulse Width=10
: In prescaled clock cycles
[Simulator Setup]
Playback Rate=100
Run Simulator=1
Invert Output=1
Wire to Output=0
Wire to Input=0
[Startup Control]
; This is the RPM level that must be reached before the xede will change over after
; startup
Startup RPM=1500
; Enter next line in seconds
Startup Delay=.5
; Enter 0 or 1 (yes or no) for next line; Needs XMap3.0.3.6 or later and XProc V3.1.14 or later..
Use Wired Bypass=0
[Pattern]
; Use PPx (Pulse-Pulse), and PWx (Pulse Width); amounts = degrees
; Max pairs = 128
PP1=1800
PW1=700
PP2=1800
PW2=700
; End of file.
Or maybe if I bridged the in and out in the xede side? I just don't want to fry anything.
Thanks for your help d
Pull out the crank out wire out of the XEDE connector, and then wire it to the crank in wire. This will create a situation where you will just be tapping off of the RPM signal so the XEDE will go online, but obviously, will still be pass through on timing.
