XEDE remote display?
Old Oct 19, 2003 | 11:37 PM
ez76's Avatar
Any plans to make a XEDE remote display/control module?
Is any part of the XEDE serial protocol documented/open, if someone wanted to try to put something together?
Old Oct 20, 2003 | 12:03 AM
shiv@vishnu's Avatar
There is a remote display module under development right now. What features did you have in mind?
Shiv
Old Oct 20, 2003 | 12:51 AM
ez76's Avatar
I'm thinking of something that could remote the XEDE status indicator as well as the sort of information you find on the XMap diagnostics screen.
A VFD packaged in a DIN slot along with a control pad (like a Nintendo controller), it could also provide a more finished bank switching interface - useful once you guys unlock the XEDE multi-bank feature.
Other things that come to mind:
  • SmartMedia slot for data logging/map loading/saving
  • Visual knock sensor (possible?)
  • On-the-fly map cell trim/boost (optional obviously)
Old Oct 22, 2003 | 01:09 PM
Obsoleteasian's Avatar
I wanna be able to play snake on mine... ..
I would also like to see a smartmedia system built in. Expansion of this toy would be nice. It seems there is a lot of untapped power in the xede, so hopefully shiv can make it compete or even beat a full replacement of the ecu.
Old Oct 22, 2003 | 02:58 PM
Ryanmcd2's Avatar
In Timeout
A/F, knock, o2 reading. I can't think of anything else. You need to make it work with the Motec Dash
Shiv
Old Oct 22, 2003 | 07:31 PM
JFawns's Avatar
Will it work with the exisiting xede??
Jeb
Old Mar 15, 2004 | 03:26 PM
asasin79's Avatar
is this still in the works? if so i would like to see:
1) Xede Function being active or inactive (just a green or red light)
2) AFR with wideband
3) EGT
4) Oil Pressure
5) Boost
don't know how many of them will actually be available through the xede w/o some type of interface. if all of this could fit into a small screen everyone could do away with gauges everywhere.
