XEDE bogging/stalling
Old Oct 27, 2003 | 11:11 AM
jman425's Avatar
Just installed my new Xede last weekend (swapped out my old unit). Everything seems to be working fine, just the annoying tick of the relay during boost. Yesterday, while merging into freeway traffic, the motor seemed to stall for about 1/4-1/2 sec during acceleration. the ticking stopped momentarily, then continued as the motor started going again ?
Anyone experience this problem ? Any inputs, Shiv ?
Old Oct 27, 2003 | 11:17 AM
shiv@vishnu's Avatar
Re: XEDE bogging/stalling
If it happened during acceleration, chances are that you hit the boost/MAF cut. To fix it, simply reduce your boost with the XMAP tuning software. All you need to do is to bring boost down by 1/2psi in the area where the cut occurred. This MAF cut issue is becoming more common since the weather has become colder.
My 2c,
Shiv
Old Oct 27, 2003 | 11:42 AM
EV0lut10n_8's Avatar
any word on the idle fix? could be part of the issue
Old Oct 27, 2003 | 11:48 AM
The idle fix is working just fine. Only took a couple of hours to revise the code. Only problem is that it recalibrates the MAF input which means that all the baseline files will have to be modified. This kinda sucks so we are working on a fix that doesn't require MAF recalibration. And nope, the on-boost hesitation is most certainly the factory boost cut rearing its ugly head.
Shiv
Old Oct 27, 2003 | 11:50 AM
ok thanks shiv....let us know when we can upload the fix...thanks again
Old Oct 27, 2003 | 11:59 AM
YEVOVIII's Avatar
MAF Cut
Will you be able to get rid of the FUEL cut and boost taper with the XFLASH?
Old Oct 27, 2003 | 12:41 PM
The XEDE assumes full control over boost so the factory boost taper isn't an issue. But, yes, XFlash will raise the factory boost/MAF cut. Not so much to run higher boost but rather to increase the buffer between the boost we want to run and where the MAF cut jumps in.
Shiv
Old Oct 27, 2003 | 01:01 PM
YEVOVIII's Avatar
HMMM
I LOVE YOU SHIV
Old Oct 27, 2003 | 01:22 PM
jman425's Avatar
Shiv - thanks for the reply. Unfortunately, I didn't look at the tach the moment it cut-off on me. I'm gonna have to do some controlled runs to figure that out.
Couple more questions... 264/272 cams pretty much what you're gonna go with ? Will you be selling "Vishnu" cams or are they gonna come from HKS ?
Old Oct 27, 2003 | 01:25 PM
Senor Loco's Avatar
That's very impressive: shiv manages to sell a so-called reflashed ECU without changing the MAF (and various other parameters) based fuel cut limit and then manages to sell more software again, and people tell him they love him.
That IS very impressive...
Old Oct 27, 2003 | 01:34 PM
YEVOVIII's Avatar
Calm down there Bonita
Im just messing around. You guys suck. Always have to dog something or someone. Why don't youi just go buy a 69 Chevelle, put some hydros on the piece crap and leave people alone. Until you have a company of your own as established at VISHNU, AMS, BR. Keep you stupid comments to yourself. Thanks
Old Oct 27, 2003 | 01:47 PM
ez76's Avatar
Do you need a hug?
Old Oct 27, 2003 | 02:00 PM
MP5's Avatar
MP5
In Timeout
Even more impressive is that your such a coward you register here today to bash. Whats even more impressive- I bet I know who this is
Old Oct 27, 2003 | 02:04 PM
Senor Loco's Avatar
Originally posted by ez76
Do you need a hug?
No, I need a PowerFC.
MP5: I know you know
Not bashing, just telling it like it is. You know it's true.
Old Oct 27, 2003 | 02:11 PM
bigd's Avatar
Actually, Vishnu is very cool about adding value for existing customers. If you look at Vishnu's history in the business, they tend to give away a lot of their hard R&D work to their existing customers.
At least, that's how many of us who have spent our money with Vishnu feel. As a consumer, I vote with my dollars. I would buy from Vishnu again without hesitation.
