relay click
relay click
any way to eliminate or drastically reduce that annoying clicking of the xede at full boost ? does this relay produce heat or can you wrap it up with some duct tape ?
Re: relay click
93 testing
hmm... some rubber foam tape, then duct tape should do the trick then if there is no fire danger. can shiv confirm this, cus i dont want my car to catch on fire from this...
Originally posted by CLeeEvo
Is it okay to rip out the beeper from the PCB? Warranty void?
Originally posted by AutoXer
Why did they not just use a coil with the same electrical properties as the factory solenoid? Is there a need for a relay? Isn't this just a dummy load?
