Problems with xede
Old Nov 25, 2003 | 11:54 PM
2fast2Furious's Avatar
In Timeout
Problems with xede
Okay I got the car back to stock and it started fine, When I look at the only plug that will go into the xede I have 2 dark green wires, no lime green wires, one of the dark green one's has a stripe and the other is solid green. Also I plugged the dark green with a stripe into the xede and when I tried the car would not start and was getting a flashing red light.
Old Nov 25, 2003 | 11:56 PM
In Timeout
**** I think this is it
Locate boost control wire. It is one of the light green wire (shown below) on the largest ECU connector (the connector furthest to the left when attached to the ECU).
Old Nov 25, 2003 | 11:59 PM
flybyevo's Avatar
If you haven't already download and print out the directions. There are color pictures in there that should help out.
Flybyevo...
Old Nov 26, 2003 | 12:06 AM
KK's Avatar
KK
EvoM Administrator
It is definitely a light green wire w/ no stripes unless there was a harness change during production. I think the harness connector with the boost control wire may have actually been to the right, not far left. Let me try and check my connector and get back to you.
Mark
Old Nov 26, 2003 | 12:10 AM
KK's Avatar
KK
EvoM Administrator
The best way to determine the correct portion of the harness would be to locate the wire just around the light green wire. I looked for black wire and a red/yellow wire and then looked to see if the light green wire was right there in relation to those two.
The installation instruction images should give a better idea of those wires in relation to the boost control wire:
http://vishnutuning.com/files/evo/Pl...directions.pdf
Mark
Old Nov 26, 2003 | 12:18 AM
In Timeout
I am going to mess with it tomorow. Need sleep
Old Nov 26, 2003 | 08:01 AM
In Timeout
Well xede 1, Ryan 0. I am getting the car towed today to someone who knows what the hell they are doing, I don't. I think I screwed one of the conectors becase now the car will not start, it started before I started screwing with it the 2nd time Oh well $500 down the pisser because I was trying to save 100 to install it.
Old Nov 26, 2003 | 09:03 AM
flybyevo's Avatar
It is fast if you take it slow...
I hope you get it going in time for turkey lurkey....
Flybyevo...
Old Nov 26, 2003 | 10:13 AM
MP5's Avatar
MP5
In Timeout
Old Nov 26, 2003 | 12:11 PM
evo1's Avatar
