Cams & Cam Gears
Old Dec 1, 2003 | 02:11 PM
evo8power's Avatar
Wink Cams & Cam Gears
Dear Shiv,
Its your favorite customer Kevin..I want to do the cam gears and sfafts and was wondering if you guys sold them and how good are they, any dyno charts before and after, and do u sell your own or HKS and other brands, i wanted to do HKS for both, and also would you recomend on a dialy driver evo 264 or 272??? thanks for your help!
Old Dec 1, 2003 | 02:17 PM
2fast2Furious's Avatar
In Timeout
I know I got my cams from him but he only had a few sets. I think it will be fine to drive daily, that's what I use my car for and I have the cams, and cam gears at home. As soon as I get the dump back I will install it all and give a write up as well as a dyno.
Old Dec 1, 2003 | 02:21 PM
evo8power's Avatar
Was also wondering and i hope Shiv responds to this......do u think i will need to remap my XEDE with the new cams and gears????
Old Dec 1, 2003 | 02:23 PM
In Timeout
From what I heard from Shiv is yes you need a new map for the cams. I have it if you want it or need it once you get the cams.
Old Dec 1, 2003 | 02:24 PM
evo8power's Avatar
thanks! ill let you know wont be for about 3 weeks though!
Old Dec 1, 2003 | 02:25 PM
In Timeout
Sounds good, the cams are a pain in the *** to find.
Old Dec 1, 2003 | 02:27 PM
evo8power's Avatar
Lancershop.com has the cams
Old Dec 1, 2003 | 02:31 PM
Sano's Avatar
from what I have read you don't HAVE to have a new map, but you wont get anywhere near the gains, so yeah you will want to get it tuned with a new map
Old Dec 1, 2003 | 02:42 PM
jfh's Avatar
jfh
2f2f,
Do you have a map for the Stage 1 + cams for 93 octane? If so, I need it also. If possible, please send via email to jfh342@yahoo.com.
Thanks,
Old Dec 1, 2003 | 02:43 PM
In Timeout
I only have it for 91, if you still want that map let me know.
Originally posted by jfh
2f2f,
Thanks,
Old Dec 1, 2003 | 03:14 PM
jfh's Avatar
jfh
2f2f:
Stage 1 + cams 91 octane map is better than no map. Please send it.
I may be able to compare it against Stage 1 (no cam) 91 octane map to determine where differences are and apply similar changes to my Stage 1 93 octane map.
thanks,
Old Dec 1, 2003 | 03:21 PM
MP5's Avatar
MP5
In Timeout
2f2f,
Thanks,
I have it get the 91 map from 2f2f or me and highlight the (MAF) on boost zones above the last 3 bottom rows and were the #s are (-). Then hit the (,) key 5 times. That worked well but what really woke the car up is go back to the original MAF settings and highlight the on boost zones (same as maf) and hit the (.) key 3 times Two hands on the steering wheel massive wheelspin and powerslides ahead- BTW I discussed this very thing with shiv also I have been monitoring it with det cans for about a week- 0 knock
Old Dec 1, 2003 | 04:09 PM
In Timeout
So if you are going straight, in 1st and floor it all 4 spin?
Old Dec 1, 2003 | 04:11 PM
MP5's Avatar
MP5
In Timeout
I can chirp them depending on the surface but the driveline lash isnt worth it
Old Dec 1, 2003 | 04:12 PM
SouthernCrane's Avatar
Sorry to go off topic, but did you go to the track last fri Evo8power?
