Already have mail Dynoflash and am going to use Xede too, do I need a boost control?
Old Dec 11, 2003 | 01:36 PM
USP45's Avatar
Question Already have mail Dynoflash and am going to use Xede too, do I need a boost control?
Old Dec 11, 2003 | 05:43 PM
Macdaddy3321132's Avatar
Re: Already have mail Dynoflash and am going to use Xede too, do I need a boost control?
I am getting 23-22 Pounds of boost on my stage 1+....
Originally posted by joeycoates
I currently have a 3" turboback, AEM intake (which I know Shiv does not like), a Type-S, an MBC, and a mail order DynoFlash. I have already ordered a 264/272 HKS cam set, ARP head studs and rod bolts, and a Walbro 255 pump. I plan on adding an Xede to help with further tuning of the setup once I have everything togather as in March I would like to run a different turbo kit, probably the RnR SC61 along with the associated larger injectors, maybe a Buschur IC although I am not totally convinced that this is needed. The flash has raised the redline as well as getting rid of the air/fuel cut which will take care of two things that the Xede cannot do. Right now I am using an MBC which is suffient for the time being, but I eventually want to use an electronic boost control. I know that the Xede will control boost, but can I increase boost over the stock setting of 19.5 lbs with it, or do I need to run something else such as the HKS EVC? If the Xede will not allow me to run the increased boost that the turbo kit will be capable of the I will need to do something else, I just do not know if the Xede will run 23-24 lbs or not. Thanks for the help in advance.
Old Dec 11, 2003 | 07:02 PM
masterevo's Avatar
Hey, just wondering on how that aem and greddy s sound? Is it loud? How is it comparing to venting to the air? Just really curious. Thx
Old Dec 11, 2003 | 07:57 PM
MP5's Avatar
MP5
In Timeout
You WILL be able to use the XEDE as a great BC for upgraded turbos Good choice solid base!
Old Dec 11, 2003 | 09:31 PM
DynoFlash's Avatar
Make SURE you send in that reflash for a upgrade before you start adding cams and the like
The exede would make a great addition over the Dyno Flash shelf map to fine tune a through the mail flash
However - we have a much better base map to tune over for the cams and other mods you have planed
Old Dec 12, 2003 | 11:28 AM
USP45's Avatar
