Stage 1 minus 1/4 mile today
Old Dec 13, 2003 | 07:10 PM
Smogrunner's Avatar
I'm not really into drag racing, but I like to go and see what I can do nonetheless. The last time I dragged a few weeks back my car was completely stock. Now, I call my Stage 1 the Stage 1 minus because I have not yet installed my cams gears. It has never been tuned; I just bolted on the exhaust and the Xede. Like last time, I added two and a half gallons of 104 unleaded. This time, I was able to run the 93 octane map. I was at Carlsbad Raceway in San Diego County.
Today, unfortunately, my tank was still on full and I had a couple of extra things in car compared to a couple of weeks ago. I estimate I was carrying between 40 and 50 pounds more than the last time I raced. Other than that, EVERYTHING was equal: Weather was about the same, same drag strip, same lane, same high rpm clutch drop. I was really hoping to be anywhere in the high 12s, but I'm satified with my improvement. Also, I am a complete inexperienced amateur drag racer. These two results are actually the only two times I have ever dragged in my life. Here is the before and after Vishnu:
Stock.......................................... With Vishnu
.726.................reaction................. .591
1.989.................60 ft .................. 1.976
5.663.................330 ft ................. 5.48
8.776 .............. 1/8et .................. 8.42
78.92 ............... 1/8 mph .............. 80.63
13.719 ............. 1/4 et ................ 13.105
100.52 ............. 1/4 mph ..............106.66
Kinda glazed my clutch today so I couldn't try a second run. But, as you can see, I did .61 secs faster and over 6 mph faster. I only wonder about what I would have run with my car completely emptied out and only two gallons of 104 inside with the 104 xmap running.
Finally, by luck, a stock Cobra Mustang was lined up with me. I smoked him, but he was an awful driver. VERY fun to knock off the V8s.
Old Dec 13, 2003 | 07:27 PM
DEL TURBO's Avatar
That's a great run. You probably would have hit the high 12's with a 1.85 60ft. Like me, I'm sure you're not thrilled by the possibility of frying the clutch.
I'm running the complete Stage 1 which was tuned by Shiv. I have plenty of Sunoco 94 octane here on the East Coast. I'd like to make a 1/4 pass after it's retuned with the 264/272 cams.
You should notice a difference with the cam gears. At our dyno session with Shiv, cars with cam gears were making 10 - 15 more whp in the higher rpms.
Old Dec 13, 2003 | 07:30 PM
Smogrunner's Avatar
By the way, reaction times do not count at all for total time. They only help you against your opponent.
Also, my clutch felt fine by the time I got on the freeway on my way home. I gave it a couple of tests when I got home and it felt normal. However, I actually saw clutch smoke come out of my hood 25 minutes after my first race. I was going to do a second run and I wanted to check my clutch so I moderately revved and slipped it in the staging area. When it smoked, I decided that I was done for the day.
Old Dec 13, 2003 | 07:54 PM
MP5's Avatar
MP5
In Timeout
Not too bad Armondo has only 2 passes on his stage 1 in waaayy south texas and ran a 12.4@111.8x on 100 unleadses Stage 1 has the power the cam gears will really help as thats the portion of the band your in. Easy 12s for sure
Old Dec 13, 2003 | 08:35 PM
Smogrunner's Avatar
Hell ya! Thanks for the input. I need to get those gears installed.
There was another EvoM member there today with a silver Evo like mine. Helli0n is his member name. I never asked him for his slips or times, but he wasn't doing too good. He had clutch problems, but not the same as other evo owner. He had a big Vivid Racing sticker running along under his doors, and one of his mods was a fancy intake box, which made me think of Shiv's comments regarding intakes. We were actually going to race each other when I experienced my clutch smoked, so I called it a day.
Old Dec 13, 2003 | 08:47 PM
alex_alex's Avatar
damn, i want to see some timeslips on 91-octane CA gas...
