Another Dyno Tale
Old Jan 13, 2004 | 06:58 PM
shiv@vishnu's Avatar
Another Dyno Tale
Stage 1 (turbo-back with optional test pipe, XEDE and cam gears)
91 and 100 octane (well, more like 97-98 since there was still some pump gas in the tank when we added the good juice)
** When the car wasn't heatsoaked (you guys know how I like to tune ), it made 300whp on two consecutive pulls
whp and torque
Boost and AFR:
Old Jan 13, 2004 | 07:05 PM
Ryanmcd3's Avatar
In Timeout
So how much WHP is the test pipe worth on the stage 1+? Also you need to max that bad boy out, no cat c16 and 25-26PSI of boost. I bet you can get 340ish on your dyno
Old Jan 13, 2004 | 07:14 PM
I bet not I'm sure with c16, we could make more midrange torque and a bit more top end. But the turbo is at max capacity up top and I don't see yanking out another 50whp. 10-20whp maybe but that's about it.
FWIW, in this application the test pipe seems to be worth at least 15whp, all other things equal.
Cheers,
Shiv
Old Jan 13, 2004 | 07:20 PM
Ryanmcd3's Avatar
In Timeout
15WHP is pretty good, is that when you pull out your high flow cat? Also Shiv that is a KILLER power curve. One other quick thing. When I go from my 91 stage 1+ map to the tuned 93 stage1+ map do you think there will be a big power difference?
Old Jan 13, 2004 | 07:32 PM
MP5's Avatar
MP5
In Timeout
Shiv this is stage 1?? GD So was that stage 1+ car putting down 300 on 91 octane??
Old Jan 13, 2004 | 07:37 PM
Ryanmcd3's Avatar
In Timeout
That's why I was asking about the 1+ map I think it will be VERY close to 300whp once he is done...
Old Jan 13, 2004 | 07:40 PM
MP5's Avatar
MP5
In Timeout
This ones at 300 without cams and mystery meat gas. What shiv is an accurate 93 octand DD map? Are we going to see the 30+ AWHP more than stage 1s? Also Im drilling out my cat then can we get rid of 0420s??
Old Jan 13, 2004 | 08:01 PM
BadBoyBeltran's Avatar
Please make the Stage 1 + for 93 octane available ASAP!!!
STi
I'm coming to get yah, or better yet, catch me iof you can!!!
Old Jan 13, 2004 | 10:48 PM
Smogrunner's Avatar
For reference, this is mine with a stage one signature WITH CAT. I was running very closely the same 97/98 octane as Bonnies because when I mixed in my 104, I still had too much 91 left in the tank. The 91 octane numbers are listed also. On the 91, I made 253hp. As you can see, I made almost 276 hp with the CAT: Even though it is two different cars, it seems Shiv is right when he says it make 15 additional horsepower. Now, my question: BEFORE I DROP THE HUNDRED + BUCKS FOR THE TEST PIPE, WILL I GET THOSE 15 HP BY JUST BOLTING IT ON OR WILL I NEED TO PLAY WITH THE XMAP/XEDE TO GET THE MOST OUT OF IT?
Old Jan 13, 2004 | 11:02 PM
MP5's Avatar
MP5
In Timeout
I am extremely interested in Shivs input. I am leaning technically that cats blow really bad and want to lean on him to offer 0420 fixes for states that dont give a damn (TX and other 3rd world states)
Old Jan 13, 2004 | 11:21 PM
Smogrunner's Avatar
Mp5, what happened to that Saleen Cobra v. You thread from this morning. Did it get deleted or sent to never never land? I can't find it. Sorry for the hijack Shiv.
Old Jan 14, 2004 | 06:26 AM
MP5's Avatar
MP5
In Timeout
Yup Mods like to delete things sometimes
Old Jan 14, 2004 | 06:37 AM
Smogrunner's Avatar
WTF? They could have moved it to "drag racing" or something.
Exposing my ignorance here, but what aspect of tuning (A/F, ignition timing, boost, etc) does a freeer flowing exhuast allow for?
Old Jan 14, 2004 | 07:48 AM
Aby@MIL.SPEC's Avatar
Could you do just a cat vs. test pipe compare on 91 octane? I am about to by a car sound cat, but If I am goiong to give up 15 whp!!! Maybe the $300 cat made by a company that I cant remember @ the moment might not be a bad option.
