Went purchasing the Xede ??
Old Jan 23, 2004 | 10:21 AM
GokuSSj4's Avatar
what are the things that you obtain as far as software ??
I have seen peeps say that you are able to download different maps from Shivs site , but do you need to install anything to your pc in order to run this maps and able to change them to the Xede . ??? Do you need any additional cables , so you are able to connected to your computer . An does it have to be a lab top or will a pc and doing the changes inside the house will work ??
I want to see what options i have on this thanks ...
Also is the Xede a plug n play , does it required an extra harness to b plug n play or just the removal of one wire (boost -green wire as i have readd) to make it work properly ??
