Xflash questions
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Click on XFlash and you get more info. The part I qouted is in the bottom third.
http://www.vishnutuning.com/xflash.htm
Thanks, unfortunetly I had missed this page. However, I wish there was more of a confident answer from their shop when I asked this question. Not the " ah...........yes, I believe so" answer.
Thanks again
Thanks again
Thanks again
Thanks again
I know with the shop I use locally, it is sometimes best just to send them an email. The experts are usually working on cars and can't take time to answer every phone call. With an email, they can answer it at the end of the day or when they have a few minutes.
Xflash doesnn't raise the boost..removing the pill is what gives Xflash higher boost without an mbc. Seems to be pretty dangerous considering that boost can spike pretty high with removal...the fluctuation alone could lead to running leaner and richer at times over the base a/f maps.
Seems a little strange that Shiv isn't responding to anyones questions.
On this page, it looks like they control boost (increase boost). I'm not sure why they couldn't raise boost?
If it doens't control boost how is he able to achive boost taper as revs increase? Boost only increases in midrange.
The reflash equipment allows boost taper adjustment to eliminate most of the boost taper. Achieving max boost and and tapering from max boost points are achieved in other ways. Works does it by using a different pill in the P2 flash.
I have an odd question??????
Why dosnt shiv reply to his product, and his questions from his potental customers on his forum?
unless mp5 is shiv of course?
I just find this odd that after 37 posts, shiv hasnt answered ANYTHING,,,,,, himself that is?
Nothing close to the support David gave from WORKS.
Maybe he is just really really busy to take a minute and post?
It is his product, and business for that matter, o well.
Originally posted by MP5
Its not in the how to use your techcom directions and requires significant ECM knowledge
I'll say this again. If you want any information from a vendor on this forum, your best bet is to send them a PM. I am sure they all have trouble monitoring their forums.
