Running lean?
Old Feb 17, 2004 | 12:16 PM
whiterexman's Avatar
Running lean?
Old Feb 17, 2004 | 12:28 PM
MP5's Avatar
MP5
In Timeout
Wait you got a map emailed from shiv? Or did you get a custom tune? I think that is my old custom map from Houston if so that makes sense as car to car variences would certainly come into play
Old Feb 17, 2004 | 12:37 PM
Yeah, I'm running on the "Stage0_nocat_93oct" map Shiv emailed me.
But this map is identical with the "Stage Zero + Downpipe 93 Octane " from Shiv's website. So I'm not sure if this is your old custom map from Houston.
Old Feb 17, 2004 | 12:49 PM
shiv@vishnu's Avatar
Running 12:1 on 93 octane isn't terribly lean. But it could be richer without giving up any power. What you can do is increase all the on-boost cells in the fuel table by 1.0. That is, if you see a -4.5, change it to -3.5. This will makes things about .5 AFR points richer. You can do this by selecting the entire on-boost portion of the fuel map (the cells which currently have negative numbers in them) and hitting the ">" sign several times until the numbers increase by 1.0.
Give that a shot.
Shiv
Old Feb 17, 2004 | 12:54 PM
MP5's Avatar
MP5
In Timeout
Give that a shot.
Shiv
Thats what we tuned it to in Houston its a good map but I agree 12:1 isnt bad but Id stil prefer to be somewhat richer
Old Feb 17, 2004 | 01:18 PM
Give that a shot.
Shiv
Thanks Shiv, I'll try that.
This might sounds like a retard question but which table/map is for the fuel adjustment?
Old Feb 17, 2004 | 01:25 PM
MP5's Avatar
MP5
In Timeout
MAF
Old Feb 17, 2004 | 01:27 PM
MAF
Ha, thanx...
Old Feb 17, 2004 | 01:42 PM
Noize's Avatar
EvoM Administrator
~300whp is pretty impressive for you mods, IMO.
Old Feb 17, 2004 | 02:13 PM
Thanx, hopefully I can stay there after fuel adjustment.
Old Feb 17, 2004 | 02:17 PM
