Difference between Stage 0 and Stage 0+?
Old Feb 2, 2004 | 07:48 PM
cjb's Avatar
cjb
I was under the impression that the Stage0+ was the downpipe + high flow cat + cat back exhaust (with the XEDE obviously). Is this true?
The reason I ask is I just got onto the XEDE that you custom tuned for my car, and the map written is described as "Stage0_91oct" under the Data Block Description. I pulled that map off the XEDE and compared it to the Stage 0 and Stage0+ maps off your website. Sure enough, it's closer to the Stage 0 map, rather than the Stage 0+ map.
I had the "dump back" exhaust car that you reference as the "with and without XEDE, baseline maps with no tuning".
I do have the downpipe + high flow cat + cat back exhaust (signature). Isn't this a dump back exhaust? Why didn't you start with the Stage 0+ map if that is the case?
Thanks.
-CJ
Old Feb 3, 2004 | 07:40 AM
Eric Lyublinsky's Avatar
Following the stages.
Stage 0= Exed and cat back
Stage 0+= Exed and cat back, Highflow cat and downpipe (Dump back is common)
Stage 1= 0+ cam gears retared 5 degrees
Stage 1+= Addtion of Cams HKS 272 264
Eric
Old Feb 3, 2004 | 07:46 AM
alex_alex's Avatar
Eric, also, for the Stage 1+, the gears are no longer retarded 5 degrees, but 3, am i correct?
Old Feb 3, 2004 | 08:06 AM
Oh yes forgot But I'm hearing -2 know is that right?
Old Feb 3, 2004 | 09:39 AM
boostedwrx's Avatar
yea -2
Old Feb 3, 2004 | 11:07 AM
jbrennen's Avatar
There's not a lot of difference between -2 and -3 on the cam gears... See Shiv's comments here:
https://www.evolutionm.net/forums/sh...972#post688006
Old Feb 9, 2004 | 04:19 PM
cjb's Avatar
cjb
Bump.
Shiv, did you put the wrong baseline map on my XEDE?
Old Feb 12, 2004 | 05:49 PM
DSMBRETT's Avatar
The name of the datablock merely indicates which baseline map I started from when tuning the car. Doesn't really matter which map I tune from as I usually start from since custom tunes get worked over during the tuning process. As to why you final map looks more like one map than the other, it just worked out that way. Nothing to be concerned about as the differences between Stage 0, Stage 1, etc,. aren't all that great. But little changes go a long way.
Regards,
Shiv
Old Feb 17, 2004 | 04:33 PM
cjb's Avatar
cjb
Shiv, check your PM...
I also just found out about the compare utility in XMap... The map that I pulled off the XEDE I named Initial_Map... Here is the compare from the 2 files.
Compare results for files
C:\Program Files\Xede\Maps\Inital_Map.XMD
and
C:\Program Files\Xede\Maps\Stage Zero + Downpipe 91 octane.XMD
Data Block Descirption different
Checking bank 0
Checking map 0
Map 0 table data (155 differences)
Checking map 1
Map 1 table data (134 differences)
Checking map 2
Checking map 3
Map 3 table data (91 differences)
381 differences found.
And…
and
C:\Program Files\Xede\Maps\Stage Zero 91 octane.XMD
Data Block version different
Checking bank 0
Checking map 0
Checking map 1
Checking map 2
Checking map 3
Map 3 table data (75 differences)
77 differences found.
Compared to Stage 0 – Stage 0+:
and
C:\Program Files\Xede\Maps\Stage Zero + Downpipe 91 Octane.XMD
Checking bank 0
Checking map 0
Checking map 1
Checking map 2
Checking map 3
Map 3 table data (90 differences)
