cel p0141
Old Mar 3, 2004 | 11:47 AM
asasin79's Avatar
cel p0141
ok i have stage 1+ and am getting a P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2). and can't figure out how to get it gone. nothing is visibly wrong with the rear o2 sensor and nothing is loose. thanks in advance hermanos.
Old Mar 3, 2004 | 12:03 PM
MP5's Avatar
MP5
In Timeout
Re: cel p0141
You been running race gas bro? Are you doing those track sessions catless?
Old Mar 3, 2004 | 01:04 PM
asasin79's Avatar
no race gas only 93oct. i'm afraid to do track on these continental tires they hardly stick at 35mph on city streets.
Old Mar 5, 2004 | 09:05 PM
asasin79's Avatar
<<<bump>>> still need help
Old Mar 6, 2004 | 06:32 AM
Noize's Avatar
EvoM Administrator
Is it a hard code.. Meaning, does the CEL stay illuminated continually until you reset the ECU? I'd pull the back O2 and try to swap with another Evo guy. Testing the sensor itself is the first logical course of action. Let us know what happens.
Old Mar 6, 2004 | 02:10 PM
asasin79's Avatar
yes it stays illuminated continually until i reset the ecu. that is a good idea any dallas area evo guys wanna help a brother out joeycoates? yevoviii?
Old Mar 6, 2004 | 03:35 PM
Noize's Avatar
EvoM Administrator
If they can't help, hit the South regional forum. It should only take a couple of minutes to swap test your back O2.
Old Mar 6, 2004 | 03:44 PM
en1gma19's Avatar
check the wires to the O2 sensor.....i had that same code after installing my test pipe (i had to extend O2 to reach the new bung.) One of the ground wires hadn't been soldered together well enough and it came apart while driving. Quick reattatchment, and no code since. If it isn't that, i'm not sure.
Old Sep 13, 2004 | 01:39 PM
mk4killer's Avatar
Hey guys i am getting this code too anything i can do to fix it?
Old Sep 13, 2004 | 08:06 PM
asasin79's Avatar
if you've never cut and soldered the o2 wires your rear o2 is fried i had to replace mine. i also replaced my cat, since the o2 got gunked. you can try cleaning your 02 sensor. i tried and was unsuccessful. good luch bro.
vincent
Old Sep 14, 2004 | 09:54 AM
mk4killer's Avatar
Hey do you buy any chance know what size of nut/bolts the stock car uses?
Old Sep 23, 2004 | 05:18 AM
[TYPE]SS's Avatar
why bother with all that, when it should be cover under warranty, unless
you went over the mileage already or car is highly modified.
Old Sep 23, 2004 | 08:26 AM
Ludikraut's Avatar
Originally Posted by [TYPE]SS
why bother with all that, when it should be cover under warranty, unless you went over the mileage already or car is highly modified.
I think stage 1+ qualifies as highly modified
l8r)
babaz7
May 22, 2016 09:57 AM
Dwilson36
May 5, 2016 11:05 AM
deathsythe99
Feb 11, 2011 12:36 PM
