Xede firmware update?
Old May 26, 2004 | 04:56 AM
93esp's Avatar
Is the latest Xede firmware update available for download anywhere? I don't really want to send my unit in for the update since I'm racing every weekend.
Thanks,
Eric
Old May 28, 2004 | 05:22 PM
HiVoltEVO8's Avatar
Arrow Firmware update
Bump for this thread. I would like to know too. I am looking forward to the logging capabilities described in an earlier post.
How about it shiv????
Old May 29, 2004 | 06:01 AM
HiVoltEVO8's Avatar
Bump
Old Jun 2, 2004 | 12:26 AM
BJai02's Avatar
Seems like Shiv is trying to ignore this question? Bump again.
Old Jun 2, 2004 | 01:28 AM
shiv@vishnu's Avatar
I'm not avoiding anything. To update the firmware, you will have to send it to us. You can do it youself but I don't encourage it unless you are comfortable with making the necessary software changes. This firmware pertains to the analog bypass and proto launch control. The newest firmware upgrade (the cool one with extra inputs, high speed logging, closed loop fuel control tuning, etc,.) is not available for public consumption yet as it will require a new version of XMAP which is currently in development. I expect to have this new upgrade ready late July. The boys from Chiptorque (in Australia) are coming out to the US next month so we can finalize this newest version of firmware and software.
Shiv
Old Jun 2, 2004 | 10:04 AM
BJai02's Avatar
Shiv
Cool! That's what I like to hear. I'll be waiting!
Old Jun 4, 2004 | 05:07 PM
n00dle's Avatar
Shiv,
Will the next firmware update still have be allowing for wideband O2 logging? If so, how will it be plugged into the Xede? Will there be provisions made via a harness or do we simply swap the stock O2 for the wideband O2.
Old Jun 4, 2004 | 05:14 PM
n00dle's Avatar
Never mind I found the answer, but please add anything you'd like to add or change.
When available, we're hoping that it will require nothing more than a simple firmware update (which most XEDE users should be able to do themselves using the XUpdate software.)
As for the wideband unit, the controller/heater circuitry will be enclosed in an external box that plugs into one of the XEDE's connectors. No wiring necessary. I suspect we will use an LSM11 wideband sensor since that's the one I do all my tuning on at our shop. It's perfectly accurate for any reasonable AFR range and reasonably inexpensive. No price estimate as yet so please don't ask
As for the knock sensing, no additional boxes necessary since the XEDE's circuit board is already wired to listen to knock. We are currently developing the associated software which will allow the user to define their own allowable knock values (in a knock table) as a function of engine speed. When the user defined knock values are exceeded, the XEDE will register a knock event. With this functional, you can use your imagination as to what we can make the XEDE do in response to the registered knock event
The neat thing about this approach is that the factory knock control system still provides a safety net which means that poorly calibrated knock tables will not result in engine failure It's simply a fine-tuning tool for those who want to go for the last 5% of power without absolutely needed to go on a dyno.
Cheers,
Shiv
Old Jun 11, 2004 | 07:59 PM
gtr's Avatar
gtr
Any updates on this? Shiv, how much if you are charging for upgrading firmware and perhaps it'll be a package deal with new PO420 proof harness? Keep us updated
Old Jun 12, 2004 | 09:26 AM
AutoXer's Avatar
Whats the data rate of the high speed logging and what can we log? I do some OBDII logging and since the XEDE basically screws with those signals it'd be nice to be able to log what the XEDE sees.
